Old 11-10-2005, 11:39 AM
Ghostang96 Ghostang96 is offline
Need Help with Gasket replacement
Ok so my brothers 97 blazer blew the intake manifold gasket. I removed the upper manifold and am currently working to get the lower manifold off. The last bolt holding it to the block is hidden underneath the A/C bracket. I got the compressor off and the top 2 bolts of the bracket off, but the 2 bottom bolts are hidden underneath the pulley. I can't seem to get the pulley off. I tried a wheel puller and all that did was start to bend the pulley. I looked closer and it seems to be held on by at driver bolt. When i tried to loosen it I couldn't get the pulley to not spin, even with the belt tension holding it. Do any of you have any advice to get this off? Once I can get the pulley off the rest of the job is doable. Get me out of this ditch!!
Old 11-10-2005, 12:27 PM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Re: Need Help with Gasket replacement
I can't think of what pulley you are talking about myself.
Old 11-10-2005, 12:37 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Re: Need Help with Gasket replacement
OK, Which pully are you talking about??????????
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-10-2005, 12:38 PM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
Common GirlBear!
Common GirlBear! Give this guy a hand you just did this!!
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Old 11-10-2005, 02:54 PM
Cailen Cailen is offline
You have to remove the AC mounting bracket itself. The bracket is holding the lower manifold on to the block.
Are you talking about the tensioner pulley? You don't need to take this off.
Old 11-10-2005, 07:37 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Youdon't actually have to remove the pulley and or bracket. If you get the a/c off and most bolts holding bracket on. gentley but forcable pry the bracket from over the bolt you can get it enough to remove the bolt. Worked 4 me. plus be very very very careful removing the manifold. there will be a tone of crap in the water ports and it will fall into the galley. any other questions on this post'em ill be watching for a lil while. but 4 now my son is bleeding so i have 2 go
http://jowulf.deviantart.com/
Old 11-10-2005, 08:19 PM
when you are looking at the engine its the pulley directly underneath the a/c compressor. It is completly covering the 2 lower bolts holding the bracket on which in turn is covering one of the bolts holding the manifold on.
Old 11-10-2005, 08:56 PM
GirlBear's Avatar
Yes I know where ur stuck. Had me 4 a while too. If u back the 1 bolt out closest to wheel well Behind the pulley it wont and cant come out but you can pry the brackett back enough to get to that last bolt. Its a minimal amout but you can doit. I used the tire iron withe the hubcab popper offer end like a bick flathead screwdriver. just enough to get that bolt.
Old 11-11-2005, 12:16 AM
OverBoardProject OverBoardProject is offline
Banned
Too bad that you didn't take some pics GirlBear.
Almost sounds like they would have helped here.
I like your art work!
Old 11-11-2005, 12:23 AM
GirlBear's Avatar
Thats the thing I did but one of my sisters or brother lost the mini disk ,they were on. I was thinkin bout going out to take photo of it anyway for him but toooooooooooooo cold!!! if he need a pic Ill drawit . Im an artist ya kno.
Old 11-11-2005, 12:32 AM
Banned
You must be a real sweetie then.
Actually taking the time to draw everything out for someone else, that you've probably ever met.
I see that you live in Hell. Weird so do I until I move tomorrow
I might try talking you into doing a drawing of my 2 rods sometime.
Give me an idea what they'll look like when they're done
Old 11-11-2005, 12:45 AM
GirlBear's Avatar
Hope this helps a real quick illustration 4 ya
Old 11-11-2005, 11:03 AM
Gabe25's Avatar
Now I know which pully your trying to take off. The power steering pully. You'll need a GM pully puller and installer. Anything else will break the pully. KD tools makes one that doesn't cost much.
Aloha
Gabe
My Fleet
