Old 11-10-2005, 11:38 AM
silveradoems silveradoems is offline
Grease fittings, 2000 1500 5.3
On my 2000 Silverado 1500, 5.3, ext. cab, Autotrac 4wd: how many grease (zerk) fittings should I find? Thanks.
Old 11-10-2005, 05:59 PM
Rammer500 Rammer500 is offline
Re: Grease fittings, 2000 1500 5.3
My 2002 Xcab 4x4 had 11.
Old 11-10-2005, 09:56 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Jack it up and count them on the front end and then add one more.for the one inside the rear double u joint if it has one.
MT
Old 11-11-2005, 12:32 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Upper ball joints, lower ball joints, inner tie-rods, outer tie-rods, 3 on the steering gear.
http://gm-trucks.com/home/content/view/123/25/
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 11-11-2005, 04:54 PM
rjirvine rjirvine is offline
To grease the zerk on the idler arm, I've found that if you turn the wheels all the way to the right you can get your grease gun on it fairly easy.
Old 11-11-2005, 06:55 PM
MT-2500's Avatar
AF - Advisor
Good info in the two upper post.
Shot I wanted him to get under there and look around
but that picture took all of the fun out of it. But good pictures anyway.
After you get the front greased get a needle for your grease gun and go look at the rear drive shaft.
There should be a needle type grease zerk fitting in the center of the rear double joint. Look close and rotate drive shaft it is hard to see.
Also check the drive shaft slip joints and u joints but most of the are not greaseable.
Give it a couple of squirts.
And while you are under the check the rear end and front rear end transfer case if you have one.
Mt
Old 11-11-2005, 08:37 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Alright, how many on a 2wd model?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 11-11-2005, 08:54 PM
MT-2500's Avatar
AF - Advisor
You may have to get under there and count them on a 2WD. Depends on the steering and pitman arms setup.
But you can count on upper and lower ball joints and outer tie rod ends
having them.
MT
Old 11-23-2005, 08:43 AM
Thanks to all for the replies. (Even MT2500 who was trying to make me learn... I had actually already looked and found 9, but was fairly sure I was missing something, so I asked.)
