Old 11-10-2005, 11:14 AM
flatlander757 flatlander757 is offline
Send a message via AIM to flatlander757
Setting up Fox for auto X?
Ok, I recently got caught racing and I've realized I need to keep that stuff off the street because it could screw with my career as an automotive technician. I am considering selling my Camaro and buying something to build as an auto X only car, but still street drivable on the weekends. I will use something else as a daily driver. I just have a general dislike for foreign cars, especially all things FWD. I'd rather go slower in turns driving a sweet looking 5.0 Mustang than a civic or mini cooper. I'm planning on getting an 89-92 GT and then making it a long term project. I don't really care what class I'll be racing in, as long as it's not against anything too nuts. I really just want to go for fun, not points or anything.
Should I look for an automatic or manual?
Hatchback or notchback?
Are taller or shorter rear gears preferred?
Tires/wheels?
Ultimately, I'd like it to be a great handling, fun to drive car that is nimble on a roadcourse and quick in a straight line for any possible drag strip runs in the future(mid 13s). I don't need any help modifying the engine, it's the chassis and brakes I need help knowing what to get. I plan on doing stuff in order like this:
-full disc brakes(probably baer or other high end manufacterer), with everything from master cylinder to pads/rotors replaced with new
-shocks/struts/springs
-set of road race wheels/tires(bogart RR series... what are good tires?)
-torque arms/a arms/panhard rod/sway bars
-something else?
Thanks for the help!
-Tony- Sold my Z28 looong ago. Now sporting an '03 TJ.
Old 11-10-2005, 06:11 PM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
Re: Setting up Fox for auto X?
if u dont wanna do anything to crazy id say do bracket racing. and u definatly need taller gears and if ur goal is mid 13's then u should go with a manual. and some DR's for tires
Old 11-11-2005, 12:28 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Use a Notch, chassis is a lot stronger.
Go to maximum motorsports or griggs, they can set you up with what ever you need.
Go coil overs, caster and camber plates as well.
3.55 are a great gear for road racing, and of course use a manual. Any of the Tremecs, or even a world class T5 can fit the bill.
Do you want to go carb or efi?
Either way, you want to make the car light! Get a good health cam, and a set of heads with intake and long tube headers.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 11-11-2005, 12:33 AM
SkylineUSA's Avatar
Don't buy any crossed drilled rotors!
Old 11-11-2005, 02:19 PM
I've been peeking around, and Maximum Motorsports seems to be a great deal for the money. Griggs is a bit out of my range for what I want it to do. The URL=http://www.maximummotorsports.com/giab2.asp#comp]Maximum Grip Box[/url] looks nice, but I think I would be better off with the Road and Track Box.
But realistically there are other things that need addressed first. I found this website: http://home.pon.net/hunnicutt/50must.htm and think it hits some key points and is very informative. After reviewing it, I think I've changed my action plan to something like this:
-Tune up w/ new plugs, wires, cap, rotor, and clean/replace fuel injectors. Also change engine/tranny/differential oil at this time
-K&N air filter
-Delete the A/C
-MM chassis brace package
-MM coil-over conversion
-3.55 or 3.73 gears, not sure(I'll have to take a ride in someone's car locally and see how they each feel)
-Here's where it will be most expensive: 5-lug and full disc brake conversion. I can't find them anywhere, but if there is a 4 lug rear disc conversion, that would be sufficient. I know you can get cobra "R" wheels in a 4 lug pattern, and they look so darn good I wouldn't mind being limited to those as a choice.
-THEN headers through an H pipe dumped under the car(who needs the extra weight of tailpipes anyways? )
I don't care how long this project takes, as long as its about done by June 07.
Old 11-11-2005, 02:42 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Yeah, call Maximum Motorsports or Griggs like mentioned above, that's really your best bet. They've got the experience in this stuff...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
