i have a93 explorer and the fuel guage does not work. I think it may be a ground wire because the rest of the guage cluster works fine. If this has happend to you or you know how to fix it please help me out. thanks
If the fuel sender for the fuel guage mounted on the in the tank pump is bad, the only fix is replace the fuel pump asy. I suggest OEM part only.
If the float for the fuel sender is bad, it can be replaced. Again, go OEM. The float from the dealer is not expensive. I think the part number for the float is COAZ.9202.B? Ask for the brass float for fuel pumps. They leak and fill with fuel and and will not float. There can also be a problem with the elec harness that is located at the top of the fuel pump asy. There is a kit available, aftermarket, but the dealer has these kits, if you ask. It includes molded connecter and new pins. Hope this helps, and good luck. In any repair that is mentioned above, one will have to drop the fuel tank. NO short cuts. Sorry. Last edited by Baranis; 11-14-2005 at 01:33 PM. |
