Old 05-28-2002, 12:40 PM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
need help
I have a couple of questions. First of all, my Sprint 1.5" springs came in. Saying that here is my story. A friend and I started to put them on and we broke the bolt on the bottom of the rear strut (passenger side). So, I'm sure I can get it out and a new one but are there any words of advice here. The car is 14 years old and the bolts are pretty much rusted on (damn FL weather). We sprayed them down with WD-40 but no luck. So, we moved to the driver side and broke an extension, then we gave up for the day. Tire place wants $250 to do the job. I don't feel like paying that for a spring swap. Any words of wisdom from past experience?
Old 05-28-2002, 07:43 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yeh i have the same freakin problem before!! If you go to performance shops it should be cheaper. They gonna say they have to cut it.If you're talkin about the rear then I figured out a way u can do it without takin the bottom strut bolt out. U can pull the spring from the top. Just take off the nuts on the top and push down on the arm. Then try pulling the spring out. Just becareful though.
Old 05-29-2002, 12:36 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
When I got my car the first thing I did was put Skunk2 coilovers on it. all of the strut bolts were rusted on from the salt, minnesota weather, but anyways what I did is go to menards and get some carbon drill bits and like a qt of oil. Then start to drill the center of the bolt out. after you get all the way through you should be able to put the new ones in there :flamer:
Old 05-29-2002, 02:02 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
Also Pick up some PB blaster and a torch, both are cheap and you will use them tons and tons. A torch, hammer, and big flathead screwdriver are my most used tools.
Old 05-29-2002, 11:10 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
I also had a siezed bolt when i had my coilovers installed.
I took it to a shop and they installed them for 160 canadian.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 06-01-2002, 09:21 PM
red4thgencivic's Avatar
red4thgencivic red4thgencivic is offline
Send a message via AIM to red4thgencivic
Alright man, I had to put a clutch in this weekend, if you're talking about where the panhard bar connects to the lower arm on the suspension then it's the same problem I had. We just used the closed end of a Snap-On brand wrench. Then put about a foot and half long bar on the end of the wrench and just pulled and jerked it until it snapped loose. We sprayed some wd-40 on it too. This should work just get as much leverage as you can. The impact wrench didn't work (we're not talkin a little puny impact wrench either, this one will break a stud off a wheel with like half trigger pressure). Anyway good luck man.
Why can't money come easier?
ok so i had two civic hatchbacks, i totaled one because i wasn't paying attention, the other one i got ran into a creek by an old lady asleep at the wheel, then i got a CRX was being retarded hit a deer at 90 and flipped, so now i drive a 1992 celica GT and i love it, done with being stupid, this one will not be wrecked.
Old 06-01-2002, 09:31 PM
Civic Rush's Avatar
If all of the bolt are rusted on like mine were you would be best off just getting new ones anyway. Just in case you want to replace the shocks. What I did (and it did come in handy) was when I did put the new bolts on I preayed some silcone spray all over it then put them in. When I put my koni adjustiables in they came right out with no problems. just some advise
Old 06-01-2002, 09:40 PM
Yeah and if you get new ones then make sure they're grade 8 all the ones I took off were either grade 8 or 10.
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
need help removine vent on passenger side of dash in 94 accord? need help on removing 94cordvtec Accord/TSX/Accord Hybrid 2 01-23-2005 09:50 PM
Help Help Help!!!!! Need Help! shahram177 Off-Topic 12 11-09-2004 07:22 AM
help i need help i need help i need help i need help lamborghiniman Diablo 1 11-24-2003 01:33 AM
Need Help On What Glue I Need For Body Kit Installation....HELP PLZ!!! branman_crx_guy '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-13-2002 08:24 PM
