Old 11-10-2005, 10:22 AM
gaelic gaelic is offline
95 blazer need help
i am on my third starter and my 4th battery when i try to turn the engine over all the lights go dim and sometimes i hear a clicking sound i tried to manually crank the engine but it wont budge i removed the spark plugs still nothing happened its a 95 4.3 vortec
Old 11-10-2005, 11:18 AM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: 95 blazer need help
Try removing your serpentine belt and spark plug. Then try to turn the engine by hand first. It sounds like something is stuck. If the motor turns freely. Then take a look at you’re a/C, Alternator, Power steering pump and Water pump to ensure that they to move freely. Try that and let us know what you find.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-10-2005, 01:26 PM
Re: Re: 95 blazer need help
when i crank the engine with my friend looking underneath at the starter he says everytime i crank it it moves 1 cog at a time
Old 11-10-2005, 02:09 PM
Gabe25's Avatar
Re: Re: Re: 95 blazer need help
Is that with your belt on or off?
Aloha
Gabe
My Fleet
Old 11-10-2005, 06:07 PM
Re: Re: Re: Re: 95 blazer need help
that is with the belt on
Old 11-10-2005, 06:20 PM
BlitzKeg's Avatar
BlitzKeg BlitzKeg is offline
hate to throw this out there but have you checked your alternater,
when your lights go dim its telling you your starter is trying to draw power but for some reason you may not have enough.
and that click is your starter solenoid It sounds functional.
you said your on the 4th battery thats a symptom of a bad alternator.
if you got a bad alternator, and once you change it you can prolly get a jump start and your new alternator will charge the drained battery.
but make sure your battery is out of juice.
it might be a loose wire somewhere.
just to make sure, you can test your alternator at most autoparts stores.
you can test starters there to
good luck!
