Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-10-2005, 10:02 AM
kyelzbub kyelzbub is offline
No heat in pickup?
Winter has come here and I am noticing that my truck is not producing heat this year. The defrost on this used to be able to melt an inch of ice of my windshield within minutes. I immediately thought heater core, but noticed something else weird. The gauge for my radiator is hardly budging at all. This I assume is telling me that my Thermostat is stuck open. Does my assumption sound right about the thermostat, and if so, would the fact that the thermostat was stuck open and not allowing the system to heat up be what's not allowing my heater core to heat up?
Old 11-10-2005, 01:53 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Your reasoning sounds good. T-stats usually fail closed, but anything's possible. Certainly a good place to start.
Sometimes another reason for no heat (assuming coolant temp is OK) is an air pocket in line to heater core.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 11-10-2005, 09:17 PM
Re: No heat in pickup?
If it is an air pocket in the line to the heater core, how would I go about fixing this?
Old 01-09-2006, 05:40 PM
imc188222 imc188222 is offline
Thats interesting. The vast majority of thermostats that I have replaced have been stuck partialy open and the complaint has been either no heat or bad gas mileage (low coolant temp keeps the ecu in open loop).
Old 01-10-2006, 01:19 PM
fourwd1's Avatar
AF -Advisor
Re: Re: No heat in pickup?
Easiest way is to raise the front of the vehicle so the radiator cap is the highest point, pull off the cap, set the control to full heat, start the vehicle and wait. Sooner or later it'll start to burp as pockets of air make their way through the system and out.
89 4Runner - stock
Old 01-11-2006, 11:51 PM
greenhorn greenhorn is offline
Re: Re: Re: No heat in pickup?
To easy replace the thermostat it's cheap. If it was only heat it might be a air bubble but since it's the whole system it will be your thermostat they can get stuck either way although closed is most common. I would eliminate the thermostat first because of the price and ease of replacement ( two bolts and a hose clamp) don't drain the system completly just undo the bolts and catch the coolant in a basin then top up later. Tom Canada
