Old 11-10-2005, 07:13 AM
Degtr Degtr is offline
'99 SE Transmission question
What would make my transmission slam into 2nd gear, especially at high RPMs, rather than shifting smoothly? I don't think it's a mechnical problem with the tranny, because I've noticed that when I have the battery cable disconnected for several minutes or more to work on the car, the tranny will shift fine for the next several times I drive it. Within a few days, though, it goes back to the very hard shift from first to second. It also doesn't happen all of the time, but enough to be annoying and concern me.
Old 11-10-2005, 11:40 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: '99 SE Transmission question
This is an automatic? Thiers an asortment of electronic equipment inside the transmission thats prone to failure. If you hav high miles, over 100k, try a fluid and filter change. Might clear it up a little.
Even newer transmissions will sometimes shift hard, just means line pressure is high(r) maybe than it should be, but its no real big deal though.
1999 Grand Am SS 3.4 OHV
Old 11-14-2005, 12:12 PM
I have over 120k, so it's probably time for a fluid and filter change again. I did it at 66k and it smoothed it out for about a week. At that time, there were no signs of any mechanical damage to the transmission as a result of it (metal in the fluid, etc.)
Old 11-14-2005, 06:52 PM
Gir-_-'s Avatar
Gir-_- Gir-_- is offline
Send a message via AIM to Gir-_-
Re: Re: '99 SE Transmission question
I need to do this with mine.. no clue when the last trans fluid was changed ie. new filter... im at 194k miles =\
04' Mazdaspeed Miata - GT2860 @ 10psi
99' GRAND AM SE V6H.O. 188whp - Sold
Old 11-15-2005, 09:44 PM
i think you both need a fluid and filter change.
Old 11-15-2005, 09:54 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
try adding either trans-x or seafoam at your next filter change. Both are excellent additives that help free up sticky shift solenoids and valves, especially in high mileage transmissions.
Old 11-17-2005, 08:48 PM
x_smoke_1's Avatar
x_smoke_1 x_smoke_1 is offline
Send a message via ICQ to x_smoke_1 Send a message via Yahoo to x_smoke_1
I was having the same problem and it was also wanting to die on me at stop lights randomly for no apparent reason. Found I had a bad vacuum hose. Not sure what it was connected to but it was located on the front of the engine on the operators side, to the right of the alternator.
BABES GOTTA LOVE THE BABES
