Old 11-09-2005, 11:29 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Weird cam gear problem!!
Has anybody ever had a d series motor do this. The cam gear is moving (spinning with timing belt) but the cam doesn't spin?? Everything is still tight, the cam gear doesn't wobble or anything. Going to pull apart here in a couple days. I'm guessing the set pin on the cam gear itself broke somehow - just sound weird.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 11-10-2005, 01:03 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: Weird cam gear problem!!
Man, if the cam gear and crank are spinning with out the cam moving your valves are screwed hardcore! If tt is indeed doing that, then yes it sounds like the woodruff pin is destroyed.
You won't know till you pull it off though.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Hybrid1990crx's Avatar
um, if you crank your motor over, and the cam didnt spin, you could have bent some valves...
Old 11-10-2005, 08:34 AM
4G4D Store's Avatar
Does anybody know if the 3rd gen motors (d15xx) are interferance or non-interferance motors??
Old 11-10-2005, 11:30 AM
my brothers 1st gen crx, aka 3rd gen civic def. was, his valves were toast when the belt when.
Old 11-10-2005, 04:27 PM
mazdatekchubyninja mazdatekchubyninja is offline
Hey The Motor Is An Interferance Motor. It Sound Like Your Cam Has Locked Up And That You Have Stripped The Pin Or Keyway In The Cam. Pull The Cam Gear Off And You Will See The Damage Pin/keyway.
Old 11-10-2005, 04:29 PM
If That Happened It Will Be Easier/cheaper To Get A Full Head Off Ebay And Replace The Head.
Old 11-10-2005, 04:31 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Dude...
Pull off your cam gear and tell me if it looks like this...
They are interference motors.... So, yeah... At least one or two bent valves. The picture is from my d15a3, but the same pricinple should apply. Check your oil jet... Mine had a foreign object get stuck in the cam journal and freeze the camshaft, causing the end of it to sheer off... More than likely, your either just missing the key, or you need a new cam and gear... So.. Good luck, though.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 11-10-2005, 09:25 PM
4G4D Store's Avatar
This is from a 3rd gen civic 4dr (not mine luckily). Does anybody have an extra head and/or cam gear? I'm thinking I'm going to need one. I believe it's the d15a3 motor from an 87 4dr.
Old 11-11-2005, 08:06 AM
Figori's Avatar
Like I said... It will probably look just like my picture.... That is the same motor you are talking about. I don't have a spare one, but I picked up the cam for just over $100, and the cam gear is like $15 from Honda.. My dad had to order a new one for my brother...
