Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-09-2005, 09:36 PM
timguyli timguyli is offline
climate control display
HELP! The temp on my electronic climate control in my 95 keeps flashing .. any ideas? Thanks
Old 11-10-2005, 08:26 PM
Malachias Malachias is offline
[color=darkorange] Does your A/C, even flashing, still working or it goes to ECON at display whem turn on? If the compressor donīt came on, check the fuse box ( fuse position # 17- white color /25 AMP ) below dashboard left side and the fuse position # 5- red color/10AMP at the fuse panel in the right side. ( you will need to take off the cover).
If the fuses are OK. tray to disconect the positive battery cable for a few moment in order to reset the A/C PROGRAMMER module.
Donīt forget to have your radio code before it.
Good luck. Keep in touch.
MALACHIAS (Brazil )
Old 11-12-2005, 08:25 AM
randman1's Avatar
randman1 randman1 is offline
Re: climate control display
A flashing display indicates a fault in the climate contro system. One of the more popular faults is a failed air mix actuator. This is a small geared motor that opens and closes a door to allow more or less air to pass through the heater core. The gears wear and eventually can not move. With this condition, you can not adjust the temp.
Old 11-12-2005, 07:36 PM
When the car is first started the temp setting will flash even without turning on the heat or air. When the air is turned on the compressor will turn on. The heat and A/C will both come on after playing with the temp setting, raising the temp up and down. Sometimes it will do it after the second time but most of the time it will take about 5-7 times. I will double check the fuses, I believe I have checked them once before.
