Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 11-09-2005, 09:33 PM
timguyli timguyli is offline
Front end Clunk on accel
Hi, My 95 has developed a clunking sound from the drivers side wheel well upon acceleration from a dead stop. Any suggestions?
Old 11-10-2005, 05:30 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Front end Clunk on accel
Check the brake and the axle shaft also check the wheel bearing for play. When wheel bearings wear they sometimes will knock when you start out not common but possible. Brake may be binding or you may have a loose caliper but my bet is that you have a CV joint on the axle shaft going out. If so it will need to be replaced.
Old 11-10-2005, 07:12 AM
cdru's Avatar
cdru cdru is offline
If it was just the CV joint, I'd expect it to make noise not just on start ups but also on corners as things shift around. I'd also look at ball joints and tie rod ends in addition to the CV joint and hub.
Vinyl adds horsepower, right?
Old 11-14-2005, 11:34 AM
llerrad llerrad is offline
Check ball joint, if cv was a problem likley you would have shake on excel. when there is the most thrust against the joint, wheel brg gone there will be constant noise transmitted through the van. So my bet is on a ball joint.
Old 11-15-2005, 10:27 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Lower control arm bushings are a common clunking problem on these vans, something to look at.
Old 11-22-2005, 10:50 AM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
CV Joint?
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
