Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 11-09-2005, 08:27 PM
jazzzmonky jazzzmonky is offline
Send a message via AIM to jazzzmonky
brakes overheat bigtime but i replaced everything
I have a 1988 ford bronco fullsize and the brakes overheat HORRIBLY. I bought it about a year ago as a project. It has about 88000 miles. Here is where I am stumped. Because of the excessive overheating I repalced the pads, rotors, calipers, lines, master cylinder, porportioning valve, and repacked the bearings all just in the front. The rear has never given me problems. Only the front overheats.
Old 11-12-2005, 09:00 PM
meteor meteor is offline
Re: brakes overheat bigtime but i replaced everything
How are the pads wearing? And by brake Lines did that include hoses. Hose are double walled and wear from the inside.
Old 11-12-2005, 10:55 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Check to see if the brakes are still on while you are driving. Maybe the piston in the caliper is still pushing while your off the pedal. Check all of the connections from the master cyclinder down.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-13-2005, 10:15 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Re: brakes overheat bigtime but i replaced everything
Also, if the brake pushrod in the booster is not adjusted properly, (too long) it can prevent the master cyl from releasing all the way. The main rod in the master cyl must come all the way or else the brake fluid pressure release post is covered. This means that as the brakes warm up a bit they will start to drag because the excess brake fluid has no place to go.
