Old 11-09-2005, 09:15 PM
wonder_hamster wonder_hamster is offline
95 Lumina Driver Side Window Problem
After I went through a drive-through restaurant today, I tried to roll my window back up, but it wouldn't budge. The window went down fine, but now it won't go back up. The other windows still work fine, by the way. It feels like when I try to push the 'up' button for the front driver's side window, it doesn't have the satisfying "click" like the other ones do when they're pressed all the way down. like something's not making a connection here. Anybody know what the problem could be?
Old 11-10-2005, 02:13 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 95 Lumina Driver Side Window Problem
Most likely the switch cluster went bad, easy to replace (1 screw), don't know what they cost for the part.
Try starting the car, holding the botton down and slamming the door while holding it down, mine's gotten stuck a couple of times, and that woke it up.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-10-2005, 02:24 PM
I also wonder...if you let the auto-down roll it down, it may not have reset when the window bottomed out (you know, that click you hear when the window stops?)
Truthfully, I am totally ignorant of how that works. But I assume it is part of the master switch cluster, since that's where you hear/feel the reset click.
Again, jarring the door while holding the button might reset it. Try it holding the button in both positions. Like I said, it's worked for me, on this and other cars....
...empty gun rack.
