Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 11-09-2005, 08:08 PM
mytacoma mytacoma is offline
Question 2005 Tacoma Rough Shifting from 1st to 2nd
Can anyone tell me if this is normal?... I just bought a 2.7L 5-speed 2005 access cab. When shifting from 1st to 2nd I hear a slight mechanical noise from the front when the clutch disengages and I often feel the gears engaging (as though, if I forced the shifting, I may grind the gears). I understand the shifting is a bit like stirring porridge but this resistance I feel only from 1st to 2nd does not seem right. I've had 4 or 5-speed vehicles before and this is the only time I've experienced this?
Thanks for any help...
Svenno
Old 11-13-2005, 12:21 PM
Jimbeau Jimbeau is offline
I have the same truck. I find shifitng rough in general. It's the first standard transmission I've owned in about 20 years. Last one was a 76 toyota carola 4cyl 5spd, and it shifted a whole lot smoother than my tacoma. I've gotten used to it, and am assuming its shifting normally. It's not bad, just certainly smooth. Jim
Old 11-13-2005, 08:53 PM
Re: 2005 Tacoma Rough Shifting from 1st to 2nd
All other shifting is fine, it's just from 1st to 2nd. It feels very strange given that I can feel in the stick, the gears turning through three stages, when I 'm shifting. Is this familiar to you? I've heard the shifting is like stirring porridge but why it seems so much rougher form 1st to 2nd I 'm not sure. I've owned 4 or 5 5-speeds in the past and I've never experienced this. I thought it would "go away" after the break in but I'm over 1000 miles and I still find myself holding back when I shift out of concern that I may damage the tranny. I'm going to take it in to the dealer to get it checked out...
Old 11-30-2005, 06:42 PM
Nstyle29's Avatar
Nstyle29 Nstyle29 is offline
Send a message via AIM to Nstyle29 Send a message via MSN to Nstyle29
I have the same deal but what i noticed is that it does it bad if it is cold, but once warm it is fine.
Check out my 95 GS-T --> http://www.cardomain.com/id/nstyle29
Old 12-02-2005, 11:37 AM
flansp flansp is offline
Re: Re: 2005 Tacoma Rough Shifting from 1st to 2nd
I have the same issue and it will be addressed when I bring the truck back for slipping out of 4th gear. Please post you findings with the dealer after you have it checked out.
Thanks,
Paul
