Old 11-09-2005, 09:01 PM
sprintcardriver sprintcardriver is offline
car is not firing
my 1992 ford mustang lx convertable does not have spark. i have replaced the crank positioning censor and had the module checked.
my car has the two coild packs and i dont think they would both go bad at once. it was running and just died the week before my timing belt broke i fixed that and drove it for week before it died. any help will be gladly appricated thanks everyone.
Old 11-09-2005, 09:58 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: car is not firing
Checked your battery? A 1992 LX shouldnt have coil packs.
1969 Cougar
357w & TKO - 475hp
Old 11-10-2005, 01:09 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Check your timing? Do you have spark? Pull one spark plug wire off, and ground it with about a 1/4 of space between it and tha chassis, crank the engine to see iof you have spark.
The car cranks but doed not fire?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 11-12-2005, 02:01 AM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
I had that problem as well. I think it may lie within that crank sensor you said was replaced or your harmonic balancer is broke some how. My 1993 had the same problem and the shop replaced the sensor and harmonic balancers because they broke both
