Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 11-09-2005, 06:41 PM
Danielt14 Danielt14 is offline
need help locating 02 sensor
i have a 99 cougar and i am trying to locate the correct sensor to change on the car. where on the engine is it at
i know that i need to find the one on bank 1
please help me.
Old 11-09-2005, 07:39 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
bank 1 is the rear of the engine. Theres 2 02 sensors on that side. One upstream and one downstream. Upstream is before the precat. Downstream is after the precat.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-09-2005, 07:47 PM
Re: need help locating 02 sensor
i hooked up a dtc to it and i get the code p0420 and that means catalyst system efficieny below threshold bank 1
my next question is do i change both of them or which one do i change?
thanx for you help
daniel
Old 11-09-2005, 09:05 PM
Re: Re: need help locating 02 sensor
thanx for you help
daniel
Chances are when you get a P0420 or P0430 code, your precat(s) are cooked. It could be a bad 02 sensor but I highly doubt it. More than likely your 02 sensor is reading correctly and telling you that your precat is bad.
Things you can do:
-Replace the upstream 02 sensor and see if that fixes it.
-Gut the precats and install a set of MIL eliminators to trick to the computer into thinking the precats are still there.
-Buy new factory exhaust manifolds (~$1600 from Ford)
-Buy a set of aftermarket headers from MSDS to eliminate the precats all together
-Reset the battery everytime the light comes on.
"The CEG Nazi"
www.contour.org
