Old 11-09-2005, 05:20 PM
bmaholic bmaholic is offline
94 Civic LX Starter?
Thanks for reading.
As you'd assume I've got a 94 Civic. When you turn the key to on, nothing happens...but when you turn it to start the engine fires up and will run. If I back the key off 2-5mm so that the starter disengages, I can get it to stay running. Of course, then when you let go of the key you're a roadblock.
Any Ideas? I just dropped it off at a place in town and the guy first told me 120 then upped it to 475. I was like....um, yeah.....not happening. Please, any and all suggestions, along with links to part shops online that you trust and purchase from.
Thanks in advance
Brian
Old 11-10-2005, 10:29 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
What did they say was wrong? One of my thoughts is that it could have something to do with the ignition switch.
Old 11-10-2005, 03:04 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: 94 Civic LX Starter?
test ignition switch wiring. pick up a helms, the haynes may possibly have the wiring diagrams for you to troubleshoot, but, dont qoute me on that though.
a new ignition switch is about $300 +.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-10-2005, 06:48 PM
lorunner lorunner is offline
when you release the key do the dash lights come on or does the entire cluster shut off?
Stop asking me about radio codes I cant get them anymore!!!
Old 11-10-2005, 08:05 PM
When I release the switch, the whole thing goes dark. However, somewhere between turning it to start and the ON position, the cluster will come back on.
I went to two places today with it. Yes, I drove it holding the key, but whaddya gonna do? So the one place had a NEW ignition switch, 475 with installation because of the breakaway bolts on this thing. They were going to drill down my old ignition (thus I would have separate keys for door and ignition, boo) and it would be new. I then went up the street and found a car parts yard and the guy sold me a used one for 50 and told me he's strip the harness (all I wanted) and install it for 75. Couldn't beat that with a stick in Atlanta.
Both people told me it was the switch part. Do you think this is correct?
Let's hope it works....
Old 11-10-2005, 08:24 PM
tune up tune up is offline
Well u can fix that by urself .what u have o do is to unscrew the 2 screws at the back of the ignition swicht (the part with the wiring .usualy its white )and clean the inside of it .take care u got some spring and balls in there... it happen to me to ..hope its that.
ok bye now good luck
Old 11-11-2005, 04:48 PM
Its just the electrical portion of the switch. There is no need to get the whole assly and recode a key. Its easy to do you can probably do it on your own. Its just 2 philips scres that hold the switch to the back of the ignition switch.
