Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 11-09-2005, 04:16 PM
DaveSev DaveSev is offline
Send a message via AIM to DaveSev
Differences between 2003 SE-R and Spec V?
^topic
AFAIK, the manual transmission on the SE-R is only a 5 speed as opposed to the Spec V's 6, and the SE-R has smaller wheels and a less firm suspension. Is that it?
Also, is the SE-R's suspension still relatively tight? Does it come with LSD?
Thanks.
Old 11-09-2005, 07:01 PM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: Differences between 2003 SE-R and Spec V?
spec has lsd, sport suspension, tuned exhaust, 6 speed, and 17 inch wheels, other than that pretty sure they are same
Old 11-09-2005, 09:56 PM
slideways...'s Avatar
slideways... slideways... is offline
(the tuned exhaust frees up 10 more hp, or so nissan claims.)
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 11-10-2005, 11:14 PM
was going to add that but figured it was redundant
Old 11-15-2005, 08:32 PM
GrimL3 GrimL3 is offline
the spec also has a higher compression rate then an SE-R i believe
Scream loud as you want to.
There's no way that they can hear you.
Old 11-15-2005, 10:02 PM
engine is the same, ecu tunign and different exhaust brought out the 10hp difference, btu the engines are the same
