Old 05-28-2002, 07:05 AM
Molotov Molotov is offline
Removing putty
Anyone know a good way of removing putty? (besides sanding)
I screwed up some side skirts i was trying to scratchbuild.
Can i use some sort of thinner to soften it up?
Left is right. Right is wrong.
Old 05-28-2002, 02:06 PM
wkma7six wkma7six is offline
Molotov, you can usually use nail polish remover or lacquer thinner to remove most puttys. But you'll have to be very careful with both of the chemicals as they can do more damge than good to the styrene plastic. I would use a scalpel shaped hobby knife to remove most of the excess putty first, then if a file( coarse ) fits into the area I want worked on I'll proceed. The final stages are to use the nail polish remover/ lacquer thinner soaked into a cotton swab/ Q-tip and remove the rest of the putty. This works very well for me, but may not work for others. Be very careful not to apply too much to the plastic! If the styrene seems to get a bit soft- STOP! Let the stuff evaporate and air out for a while til the plastic hardens again. Molotov-you have been warned and Good luck! E-mail me for more questions. -Walter
Old 05-29-2002, 09:06 AM
Daryl's Avatar
Daryl Daryl is offline
Thanks for the tip..
I'll try that cos i really screwed up my first attempt. This time i think i'll try using sheet styrene.
BTW.. Daryl = Molotov.
For some reason i couldn't access my account and had to reset.
'00 COUGAR removing dash gw84 Cougar 0 04-28-2009 08:08 AM
1994 b-3000 radio removal zoobag General Discussion 1 04-05-2009 05:22 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
Can you remove putty? Ghost_9418 Car Modeling 7 08-30-2003 01:48 PM
