MAF sensor
I know maf sensors are delicate and a little expensive...... so whats the proper way of cleaning one on a 97 blazer, what should i use to clean it with?
Re: MAF sensor
Just spray it with some brake cleaner or electronics cleaner. Don't use any other types of cleaners, because they will leave a residue.
Running To Rich
Can Someone Tell Me Where The Maf Sensor Is Located
On A 95 4.3 |
Re: Running To Rich
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Re: MAF sensor
I used rubbing alcohol to clean mine and it worked pretty well. I don't know if the alcohol left any residue behind though.
Re: MAF sensor
isopropyl does, witch hazel doesn't.
Re: MAF sensor
witch hazel is some old school voodoo you say the right incantation start the fire under your culdron and then go pick some up at your closest natural food store. Its an astringent or extract derived from the yellow cold weather flowering bush (tree, bush.. they can get big where i come from) of the same name that is actually used in alot of cosmetics astringents.
so is it safe to say NOT to use WD40, or can you?
1997 Blazer LT 204k miles, 4X4, BF Goodrich AT's, 2 Pioneer 6x9's, 12" IMPP subwoofer with 1000watt Pyramid Amp. CAI. |
Re: MAF sensor
Re: MAF sensor
MFG recommended cleaner for MAF's is electrical parts cleaner, brake clean can leave a residue, actually brake clean should not even be used on rotors. After refinishing hot water a detergent is recommended, I'll admit though, I use brake clean on used rotors to clean of my greasy finger prints.
I used a little bit of paint thinner on a Q-tip, it worked great, really cut the black grime that was on the wires.
Re: MAF sensor
Re: MAF sensor
I prefer acetone
Re: Running To Rich
After some searching for it in my 95 4.3L CMFI OBD-II and searching at AutoZone.com I come to the conclusion that I do not have a MAF in my Blazer Just a MAP sensor.MAF came 96 with the CSFI fuel system! /Freddy Last edited by frehol; 01-09-2006 at 12:33 AM. |
