Old 05-28-2002, 05:09 AM
Rampicatore Rampicatore is offline
Unhappy Engine problem - drained battery
Hi. A few weeks ago I bought a 1969 BMW 2000. The engine won't start.
First it turned but died. Now it just gives a click and that's it. I've changed the oil , replaced the battery for a high capacity one , changed the cooling , put in new sparkplugs and HTleads and there's enough gas in the tank (normal unleaded with leadreplacer). It seems like something drains my battery empty. Any idea what it could be?
2° question : the springs are in need of replacement . Could be confirmed just by looking at them. The schockabsorbers themselves however ... . How do I know they need to be replaced too ?
Thanks alot in advance !
Old 05-28-2002, 10:23 AM
AEstud's Avatar
AEstud AEstud is offline
Send a message via ICQ to AEstud Send a message via AIM to AEstud
ever think about having your alternator or starter looked at?
Old 05-28-2002, 11:00 AM
enginerd's Avatar
enginerd enginerd is offline
There is a drain on the battery somewhere. Look for loose connections and check the radio (especially if it is aftermarket). Often, owners will install radios and not wire them correctly or to the original harness and the battery will drain because of it. The shocks can be checked with the jounce test. Put your knee on the front bumper and jounce (bounce) the car up and down several times, gathering momentum. If the car rebounds more than twice, the shocks are bad.
Kittyloaf™ spectrum analysis
Old 05-28-2002, 03:24 PM
My guess was the alternator too. Does anybody know if a new alternator or starter could be used in my old car? Since I'm not restoring the car to it"s original state , I don't mind using modern pieces. (I'm trying to make a custom out of it.)
- the batterycable for the negative pole is in bad condition. Can this cable be replaced easily or are there any restrictions ?
Thanks for the help on the shockabsorbers! I think it would be safer to replace the absorbers too and not just the springs.
As for the battery , there isn't a radio installed. But can a short circuit of the switch of the headlights also be one of the reasons why the battery is drained?
Thanx
Old 05-28-2002, 04:30 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Usually the clicking sound is the sound of a dead battery. I think something must be draining it. Before you bought it, was it running?
Old 05-28-2002, 04:33 PM
enginerd's Avatar
Thanx
I'd first have the charging system tested and if it's fine, you have a drain somewhere. With a car that old, some wire has probably rubbed it's insulation off on a metal part.
Old 05-28-2002, 05:44 PM
The car had been stalled for about 9 months when I bought it.
The previous owner had driven it one time before that.
From the owner's manual you could read that the car has been used daily from 1969 till 1990. Later till about 1996 it was used occasionaly and from 1996 it has been put in a garage. So it has been a while , to say the least , that the car has been running. The engine has about 120.000 km (about 75.000miles)
I still bought it because of the following reasons :
1. I'm very fond of the "60-"70 BMWcars and this one in particular.
2. My dad drove one when he was younger and still likes to talk about (you have to know my dad thinks of cars as being just a way of transportation)
3. It was in a fairly good condition. Chassis very good , interiour in leather like new , body had only rust at the place of the sparetire and front-bumper.
4. For european measures a rather large car (4.45 meters). At the moment I drive a Ford Fiesta which is about 3.85 meters).
5. A powerful engine (2000cc) for european measures.
6. Body has a lot of genuine chromeparts.
7. Can be easily converted to a nice custom American style , what I'm planning to do.
Before I start on the body , I would like to have the engine running. I know it"s not going to be easy , but it"s a hobby . Working on my car actually keeps me from getting insane
Old 06-02-2002, 05:44 PM
The Dude The Dude is offline
Sounds like starter. But put a volt meter on you battery. Say 12 volts. IF not id take all your fuses out and just put in the ones you need to start the car. What kind of click is it? Is it coming under the car? Is it coming from inside the steering wheel?
Old 06-02-2002, 07:22 PM
texan's Avatar
texan texan is offline
Writer Mod
Agreed on the starter part, but I'd be more likely to think it's either a bad selenoid or a starter well past its prime. First hook up a set of jumper cables directly to the starter (ground to engine ground, positive to starter positive). This bypasses everything else that could be wrong other than the starter itself, if it's an otherwise electrical problem you'll still get cold cranking but the engine won't fire.
If it still clicks when hooked up in this fashion, get a ball peen hammer and tap the start casing. When a starter motor is starting to die this will generally kickstart it back to life a few more times, as the brushes continue to wear though it'll eventually die for good. If this works, just get a new starter as soon as possible and meanwhile carry around a small hammer.
If that doesn't work either, it's the starter selenoid or motor. Replace the starter, and make absolutely sure the flywheel teeth are in good condition when you go about it. A very old starter can cause havoc with the flywheel teeth if it's been hard to start for years.
'03 Corvette Z06
'99 Prelude SH
Old 06-03-2002, 03:37 PM
Thankx for the advice ! I will try it right after I come from work.
I'll keep you informed
Old 06-04-2002, 03:20 AM
Hey texan are the solenoids on bmw/s on the starter? I dont know much bout bmw's
2001 gls battery drain jetta_help_needed Jetta/Vento/Bora 7 02-18-2011 12:37 AM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 10:04 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
heater fan still runs after engine off - drains battery sctrotts Trans Sport 2 03-07-2008 12:43 PM
Electrical Problem draining battery Richard123 Caravan | Voyager 0 02-25-2004 08:27 AM
