Old 11-09-2005, 01:05 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
95 putting
have a 95 4dr 4X4 cpi with 199,000 miles on it. running pretty horrible lately. after reading threads on changing the CPI, i took to it. changed out the cpi and nut kit. all was well. took it for a test drive, still putting. ran some seafoam through the engine, and chnaged the plugs afterwards. still putting down the road. i have done a FULL tune-up and was wondering where i should look next.. thanks
Old 11-09-2005, 02:26 PM
xjcamaro89 xjcamaro89 is offline
Clean MAF?, try it, it made a world of difference for me
Old 11-09-2005, 02:27 PM
Re: 95 putting
did that already....thanks
Old 11-09-2005, 02:32 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Re: 95 putting
Try pulling your EGR valve and check for carbons chunks. Clean it out with some brakelean and make sure the plunger is moving freely. Reinstall it with a new gasket. See if that helps.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-09-2005, 03:14 PM
93LT 93LT is offline
Re: 95 putting
Did you check your vacuum hoses? Starting with the one off the back of the intake and going out from there.
Old 11-09-2005, 03:19 PM
Re: 95 putting
cleaned the EGR passage when i changed the CPI. all vaccumn hose are attached and good... im lost here....
Old 11-09-2005, 03:31 PM
drdd's Avatar
drdd drdd is offline
Re: 95 putting
what brand plugs did you use ?
is it putting at idle or all the time? did you clean the IAC?
any codes?
hmmmm .... after a full tune up? hhmmmm ...
you didn't mess with the timing did you? don't 95s need to be set with a timing-light?
hmm ... you might try H20 decarbonizing, or another dose of seafoam ...
Old 11-09-2005, 03:36 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 95 putting
Sounds like you've covered most things. Have you checked to see if the fuel pressure is low? Considered the possibility of a clogged cat? If your CPI was leaking, it could have killed your cat in no time at all.
Old 11-09-2005, 08:13 PM
Re: 95 putting
hmm i didnt check my cat, i need a new exhaust. my muffler is rusting through. ill have them check my cat out tomorrow. ill bring it by the shop and have them check it out. i didnt know a clogged cat could cause putting.
Old 11-09-2005, 08:27 PM
Re: 95 putting
sorry, i used ACDELCO plugs, rapid fire. gapped correctly. it is putting the same way it did before i changed the CPI and nut kit out....
Old 11-09-2005, 08:46 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 95 putting
How about the cap and rotor?
Check the coil to cap wire as well, it tends to corrode in the coil end.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-10-2005, 02:21 AM
Re: 95 putting
i changed out the cap and rotor when i did my tune up... everything that should have been changed was changed
Old 11-10-2005, 10:02 AM
Re: 95 putting
strange....i went out last night and my car wasnt putting... whats going on? i drove about an hour away without one put from my engine. im sure it will come back
Old 11-10-2005, 10:42 AM
ChrisGood's Avatar
ChrisGood ChrisGood is offline
Re: 95 putting
Well I would take it to the driving range, get it to stop putting and start driving. Good grip and form are key, oh and the right set of clubs helps.
I can fix anything, if you just tell me how.
White 2006 Chrysler Town & Country
Zurich Pearl White 1993 3000GT VR4
1993 3000GT VR4
Old 11-10-2005, 11:35 AM
Re: 95 putting
well its back to driving, no more putting. haha dont know what heppened between yesturday morning and aftenoon but it is driving smooth as can be right now. thanks
