Old 11-09-2005, 12:06 PM
khregg khregg is offline
94 s-10
recently, my s-10 blazer has had problems starting. when it sits overnight, i have to turn it over for more than a few seconds before it gets going. when i turn it off and start it within a short time, say 10 minutes, it starts right up. could this be my fuel pump causing me problems? i guess i shouldn't complain too much considering i am close to 180,000 miles.
Old 11-09-2005, 02:06 PM
RahX RahX is offline
sounds like it. what engine is in it?
Old 11-10-2005, 05:04 PM
its the 4.3L vortec
Old 11-10-2005, 11:35 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: 94 s-10
every time you turn your key, listen for the fuel pump 2 second energized prime, if its not there its the pump for sure (a hummmm sound) but, just because its there doesnt mean the pressure is up to snuff
Old 11-11-2005, 07:01 AM
hakogen's Avatar
hakogen hakogen is offline
Re: 94 s-10
my '01 2.2 has been doing the same thing w/ a brand new fuel pump... i'm thinking it might be the erg now... you should check that too.
Old 11-11-2005, 01:11 PM
i will listen for the fuel pump next time i start it up and go from there. thanks.
Old 11-25-2005, 03:34 AM
apache59 apache59 is offline
Re: 94 s-10
I wouldn't think that it is the fuel pump, they generally go out all at once. Check your fuel lines for pressure at the plenom fitting in the morning to see if the fuel is bleeding back into the tank over night.
Old 11-25-2005, 11:22 AM
sector95 sector95 is offline
Re: 94 s-10
As was already suggested, before cranking the engine let the fuel pump run until it builds system pressure (you'll hear it run for a few seconds then shut off) before cranking the engine.
Also.... when was the last time the fuel filter was changed? It lives alongside the drivers side frame rail about half way back.
You probably have throttle body fuel injection (looks like a strreamlined carb) and cleaning the injectors is relatively easy. Get a can of spray carb cleaner (some good stuff lke CRC or Gumout) and take the spritzer straw and bend just the very end of it up so it points upwards. You want to be able to insert the straw into the throttle body and direct the stream upwards to the underside of the injectors; this is where the fuel spray comes out and is just about impossible to clean unless you modify the little straw.
Run a double dose of Chevron's Techron in a 1/2 tank of gas. Yes it's expensive but it works very well; you'll waste your money with the other "pour-in-the-tank" injector cleaners.
mike
Old 11-25-2005, 11:09 PM
Re: Re: 94 s-10
the fuel pump is a positive displacement pump and it should hold pressure, if its not then the pump needs to be replaced. thats not to say it still doesnt work great when its warmed up.
