Old 11-09-2005, 11:58 AM
creepy6400 creepy6400 is offline
Question check eng light off
i have a 96 escort wagon. I've owned it since 99. For the 1st 2 yrs the check engine light was on all the time but no problem could be found. I took it to the Dealer and they said they fixed it but about 48 hours later it came back on. Fast-forward to now. I got it inspected & it failed because the check engine light(c.e.l.) won't come on at all!
So I have to fix it or go back to the dealer which I want to avoid. I looked all thru the fuses and switches under the dash and read in the manual that the c.e.l. sometimes malfunctions if an alarm has been installed wrong. There is an alarm in my car which it came wih and I wonder if this is the problem? if so, how can i check this to see?
thanks...
Old 11-09-2005, 05:59 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: check eng light off
Is the bulb good?
Nevada Tumbleweed
Old 11-09-2005, 06:32 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
yeah i bet the bulb
Old 11-09-2005, 11:53 PM
Davescort97 Davescort97 is offline
Escort guy
I don't know much about the check engine light and the computer, but I do know that while I was working under the hood I took the fuse for the computer (OBDll) in the engine compartment out to check it. It made my check engine light come on. I disconnected the negative terminal of the battery for 15 minutes and the light went out and has never come back on again. I'm thinking you could do this to see if your bulb in your CEL is working. I'm almost 100% sure that this will make your light come on if it has a good bulb. But, like Az and zx2 say, if the light was on nonstop for 2 years it probably burned the bulb out.
Old 11-10-2005, 04:16 AM
To test the bulb simply turn on the ignition. The bulb should be on with the engine off.
Nevada Tumbleweed
Old 11-10-2005, 09:23 AM
check eng light
Hi Folks, thanks for the tips. I met a guy across the street who has a friend who does electric work for cars and he came and took a look and ran some test real quick (like the one Davescort said) and it does indeed seem to be the bulb. He is coming back over tonight to change it. I could not even begin to figure out how to get that dash off.
Ciao,
Old 11-10-2005, 03:24 PM
Be careful of a friend of a friend who does electrical work. Scarey thought
Nevada Tumbleweed
