Old 11-09-2005, 10:09 AM
iroczman's Avatar
iroczman iroczman is offline
tpi on 400
will a tpi system fit on and work properly on a chevy small-block 400? cause i got wondering and isnt that block all most the same as a 350. i dont think it will.
89 iroc tired tpi 305, 700r-4 and 2.73 posi rearend
soon to be my LITTLE RED NIGHTMARE!!!!! (in storage)
99 grand prix silver 3.8 loaded (daily driver with 190,500 miles and going like a top!)
POOR COLLEGE STUDENT!!!!!!!!!!!!!!!
Old 11-09-2005, 10:42 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: tpi on 400
The only problem I can really see with it is computer calibration. The 400 isn't a high-revving engine, so better intake runners aren't necessary. It should work, but you might need a special PROM for it.
Old 11-09-2005, 12:48 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: tpi on 400
you will absolutely need a prom tune and you would want to have upgraded runners, base, and ported plenum. 400 is gonna want to breath. But it should all bolt up as long as you have the right year heads for it all to bolt up to.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 11-09-2005, 07:22 PM
silicon212's Avatar
Confoundingly Lucid
Re: tpi on 400
Keep in mind that porting the plenum makes it breathe on the high end, but somewhat kills performance on the lower end. Same thing applies for cylinder heads and intake runners.
A 400 utilizing the 5.565" connecting rods is not a good high-rev motor. Piston side-loading comes into play with the shorter rods. If you are building a high-rev motor, then stick with a 350 and go ahead and port the intake. The 400 as prepared from the factory also tends to run hot under high load due to the layout of the water jackets. There are tricks to getting these blocks to run cooler - NASCAR runs these 4.125" bore siamesed cylinder blocks, but with shorter strokes (3.33") for 358 CID. They obviously work well in that application, but then again look at the stroke and the length rods (6.00") they use.
Don't spend a lot of time trying to make the TPI flow better for a motor that's never going to use it. You can put larger runners on it, but that's as far as I'd go. The 400, as delivered by Chevrolet, was a torque motor pure and simple.
If you use later heads with centerbolt valve covers on your 400, make sure they have larger chambers (76cc) and you will also need to drill the steam holes between the cylinders. Look at your current heads for reference.
Old 11-09-2005, 08:37 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
Re: tpi on 400
my car (which i bought today) has a 400 and its tpi. works great.....
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
