Old 11-09-2005, 09:09 AM
titanowner titanowner is offline
2000 Cavalier that died on the road
The car acted sluggish and just died on the interstate. This happened suddenly. It will still act like it wants to start but won't. Every fuse was checked and they are alright. The lights all run fine, it just acts like it isn't getting any fuel. Any suggestions how to check for a bad fuel pump or whatever else may be the problem?
Old 11-15-2005, 08:01 PM
quake61's Avatar
quake61 quake61 is offline
Re: 2000 Cavalier that died on the road
everytime u want to cranck the engine u have to hear the fuel pump
if u dont hear the pump check for relay and fuse if that is ok
then bad pump
u can also check for fuel pressure in the fuel rail just to make sure there is fuel there
Old 11-16-2005, 01:50 AM
greg9034 greg9034 is offline
I had the same problem with my 01 2.2. It ended up being a bad fuel pump at 15k.
Old 12-02-2005, 06:30 PM
Foxtrap Foxtrap is offline
When my 2000 Cavalier died it was just out of gas even though the gauge said I had a 1/4 tank. What happened was Shell gas was screwing up my fuel sensor. Instead of having it replaced I changed gas stations and everything started to work again.
