Brakes and passenger side sliding door
Back in June of this year I had the axle shaft, wheel bearing and spindle replaced on the passenger side front and every since that day (I mean from the frist time I applied my brakes after leaving the garage) it feels like they are grabbing or that the ABS is coming on every time. We have taken off the wheel and apart the brakes and there is some play, about 1/4 to 1/2 inch, with the router. I can "push" thru this grabbing and the brakes feel normal again but this this is happening consistently. The ABS light comes on and just recently the parking brake light as well. It seems that while these light are on, my brakes work fine. Any ideas on what is causing this?
My passenger side sliding door seems to be making noise like it is rattling or loose but cannot locate any loose parts which would cause this. If I grab hold of the handle on the outside, I am able to lift the door up approximately 1/2 to 1 inches. Is this normal or is this my problem? Any info on either problem would be greatly appreciated. |
Re: Brakes and passenger side sliding door
I would have pulled right back into the garage and said "the brakes were fine when I brought the van in and now they're doing this:......." The ABS and Brake light may come on when there is a error brake system. Your ABS wheel sensor may of not been plugged back in, the wiring to it may of been damaged when the hub was replaced or the sensor may be damaged. It doesn't sound like your van was test driven after the repair. I don't know how long the shop you took it too will stand behind their work, but I'd bring it back. You shouldn't have to fix a probem brought on by a shop fixing anohter problem that you paid for. As for the door....???someone would have to look at it, listen, and then go from there. Regards Dan |
I have detailed pictures on the '96 front disk brakes.....and removal of the interior trim panel for the front door at
http://community.webshots.com/album/201931518cScpNK |
