Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 11-09-2005, 08:20 AM
Freddy2121 Freddy2121 is offline
Denali Grill
Does anyone know where I can get the FULL factory Denali Grill, not an insert? I have found the standard Yukon Grill, but the parking lights do not fit. Any help?
Fred
ATL
Old 11-11-2005, 10:21 AM
attackdog attackdog is offline
You can pick up a set of clear signal lights on ebay motors. Then the grill will fit fine. I think I saw them awhile ago for about $30.
Old 11-11-2005, 11:02 AM
Re: Denali Grill
I found those lights, but the Denali lights won't fit in the standard Yukon Grille. I am trying to get a Denali Grill.
Old 11-12-2005, 08:36 PM
GuMan GuMan is offline
gmpartsdirect.com
GM PART # 15764319
CATEGORY: Radiator Grille
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $449.85
OUR PRICE: $265.41
DESCRIPTION: GRILLE
Old 11-15-2005, 06:03 PM
tonytone tonytone is offline
Re: Re: Denali Grill
I can only assume that, a) you have a regular Yukon--i.e., not a Denali; and b) if it is a regular Yukon, you've swapped out the Yukon front bumper for the Denali one...as I'm sure you're aware that the Denali front grill will not mount correctly above the Yukon front bumper due to the fact that the Denali grill does not have that dip in the lower grill portion like the Yukon grill.
Old 11-18-2005, 07:11 AM
Re: Re: Re: Denali Grill
So Should I be okay if I purchase the Denali bumper cover shown here
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
and then the Grill?
or are there additional modifications I need to make? Also, will this bumper even fit onto my regular Yukon?
Old 11-18-2005, 07:14 AM
Re: Denali Grill
Originally Posted by GuMan
gmpartsdirect.com
GM PART # 15764319
GM LIST: $449.85
OUR PRICE: $265.41
DESCRIPTION: GRILLE
There is no picture. Is the a DENALI Grill or a Standard Yukon Grill?
Old 11-21-2005, 04:04 PM
Re: Re: Re: Re: Denali Grill
and then the Grill?
Yes, but you will need other additional parts (front bumper brace or something like that) needed to install the Denali bumper cover correctly--IOW, I believe the Denali cover won't just bolt right over the existing mounts meant for the regular Yukon cover. Then you'll ideally want to get the Denali fog lights and lower grill/insert to make the front bumper conversion ALMOST complete. Almost, as in...you'll either need to get the Denali front license plate bracket or find something to cover the holes where the bracket mounts to...and also perhaps swap out the Yukon headlight housings for the Denali projector ones...which BTW if you do, you need to ensure that they have the harness adapters so that the existing Yukon headlight connectors will plug in correctly since the Denali uses 9005 bulbs for low beams and the Yukon uses 9006. I mention this because some aftermarket Denali headlight housings don't come with this adapter...and unless you don't mind notching the existing Yukon adapter so that you can plug a 9005 bulb to it, you will need this adapter. The headlight swap is optional but hey, if you want to go all the way w/ the Denali front-end swap, you might as well do a complete swap.
