Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-09-2005, 02:00 AM
98Lud 98Lud is offline
Post Check Engine Light and No VTec
I have a 98 Prelude SH, my check engine light just came on a couple of days ago and i've checked the oil and its fine, and my VTec is not kickin in, and sometime when i drive my car, the idle will change for no good reason to 1500 and it will stay that way until i turn off the car and turn it back on then it goes to normal. When i start driving it again it goes to 1500 (only happens every so often), its been happening more and more often lately.
Could it be because of my 2 broken engine mounts??????????, i just ordered hasport, and i'm waiting for my order, but i'm still worried it about it. Let me know if anybody knows anything about my situation
Thanks, Lud For Life
Old 11-09-2005, 02:31 AM
Gohan Ryu Gohan Ryu is offline
Re: Check Engine Light and No VTec
Search this forum for how to pull the code from the ECU - that'll tell you exactly what's wrong.
Old 11-14-2005, 11:16 AM
Re: Re: Check Engine Light and No VTec
i talked to my friend and he tried to do that with his ECU on his 95 Honda Civic Ex and then he tried mine... because he knows how... and he said that my car is OBD2 and i'd have to take it to take it to a computer... is there any other way... then a computer...??????????
Old 11-14-2005, 12:33 PM
cas4067 cas4067 is offline
Re: Re: Re: Check Engine Light and No VTec
Take it to autozone they will hook it up to a comp. and tell why yout cel is on... by the way it's freeeeeeeeee
check it out let me know what you think
my ride
Old 11-15-2005, 10:52 AM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
I would go down to autozone and have them pull the codes. there's no way it's related to the engine mounts. Could be the IAC or maybe one of your O2 sensors. Do not disconnect the battery to turn off the engine light, get the codes so you know exactly what the problem is. Autozone checks codes for free.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 11-15-2005, 08:26 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Sounds like a bad 02 sensor or TPS sensor. Take it to autozone like everyone else said and get the code.
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 11-28-2005, 12:46 AM
Thanks for your help guys, I took it to AutoZone and they told me that its the Engine Temperture Sensor.
Old 12-18-2005, 05:05 PM
twizzaut's Avatar
twizzaut twizzaut is offline
as for ur vtec not working u might be low on oil. if ur oil pressure is low then there will be no vtec
HöÑÐã§ 4 Lïƒê
Old 12-19-2005, 06:16 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
troubleshooting is pointless without pulling the cel first.
http://www.honda-tech.com/zerothread?id=1171263
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
