| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
I have a 90 talon tsi and it grinds gears from first to second.
what to do! |
uhhhh.....fix it! LoL
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Re: Grinding Gears
When was your last tranny gear oil change?
Re: Grinding Gears
At the very least learn to double clutch. For example : Shifting up is fairly easy, push clutch in, put into nutral, let clutch out, immediately push clutch back in, and into gear, clutch out.
Shifting down is a little tricky : Bring RPMs down to 2000, clutch in, put into nutral, let clutch out, rev engine to corosponding RPM for lower gear (usually around 1000 RPM higher than whatever you where at) engage clutch, put in gear, let out clutch. All of this has to take place quite quickly. If it lurches forward when you let out the clutch, you reved too high. If it drags the vehicle down you didn't rev high enough. Basicly when you have the clutch out in nutral you can control how fast your transmision is spinning. Hope this helps.
95 Talon Tsi AWD 5spd 2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
