Old 11-08-2005, 05:52 PM
kaos8704 kaos8704 is offline
timing belt issues
im a newbie, i just bought a 94 non turbo. i needed to replace the timing belt on it, the cams all jumped i cant find info anywhere on how to get it back to into the correct timing. any help would be very appriciative
thanx
shane
Old 11-08-2005, 06:09 PM
Gateway's Avatar
Gateway Gateway is offline
Re: timing belt issues
www.stealth316.com is a great resource.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 11-09-2005, 09:00 AM
TMD TMD is offline
Look at the back side of the pulleys. There are lines on them. They must align with the marks below the valve covers.
On the crank pulley, there is an alignment mark.
Align all 5 of them and you are set.
TMD
Old 11-09-2005, 10:04 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
here's the documented process on how to correctly do the 60k service (which includes changing the timing belt).
http://www.team3s.com/60k.htm
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
