Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-08-2005, 05:04 PM
sediver sediver is offline
Question Changing an Oil Pressure Sender 4.3L
On my 1995 GMC Jimmy 4.3L, I need to change the oil pressure sender and I wondered is it possible to do so without removing the distributor ? I was "looking" at it today and it looks like a "bear" to get at without removing the distributor.
Thanks for your time,
SEDIVER
Tucson, AZ
Old 11-09-2005, 06:14 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Changing an Oil Pressure Sender 4.3L
You don't need to remove the distributor... Just get an oil sender socket... There are 2 sizes... Typically if you have the original sender, you will need the larger one, the new one will fit the smaller oil sender socket.. Simply put the socket over the top and use a crecent or box wrench to turn it counter clockwise.
Old 11-12-2005, 07:13 PM
Re: Re: Changing an Oil Pressure Sender 4.3L
Thanks for your reply,
I changed it out and all is well....man, what a place to put the sender !!!
Take care,
SEDIVER
