Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-08-2005, 03:14 PM
Lead Foot Lead Foot is offline
Front Suspension Noise ('01 LS V8)
I am hearing a tapping sound from the front suspension when riding over small bumps or pits in the road. It's not a thump which would be a deeper toned sound; it is kind of a tickety-tack sound only heard over bumps. I replaced the swaybar endlinks (dog bones) last week ... the old ones didn't look that bad, but I did it none the less. The noise however is still there and unchanged. Any thoughts??
PS - I used to have lowering springs on a previous car that would chatter due to the progressive rate design. The sound is quite remeniscent of that, although the LS still has all stock suspension.
... patiently waiting on the Eibachs and Magnaflow!
Old 11-08-2005, 03:20 PM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: Front Suspension Noise ('01 LS V8)
It's probably your brake pads. My last set did that until I replaced them with ones that included the anti-rattle clip...
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
Old 11-08-2005, 03:26 PM
Re: Re: Front Suspension Noise ('01 LS V8)
Really, how would you check for this? Whats the anti-rattle clip look like? Never thought of the brake pads.
Old 11-09-2005, 06:37 AM
CGGorman's Avatar
They are metal clips that snap onto the pad backing. They should be included in the brake kit, but probably are NOT pre-installed on the pad.
Old 11-09-2005, 07:53 AM
Thanks, I'll check it out. Any other thoughts?
Old 11-09-2005, 12:33 PM
CGGorman's Avatar
My experience points toward the clips, but the stabilizer bar bushings are also suspect, as well as the ball joints. I've not heard anything about the control arm bushings or strut mounts, other than isolated cases.
Old 11-10-2005, 12:17 PM
Found the source. I installed my front Eibach springs today and noticed on both sides that the upper bumpstop hat was detached from the upper coil seat (see below). So I removed them ... simple as that. Drove the car for about 10 minutes over familiar roads where I knew the noise would occur and now it's gone. Just another check for those having front end noises ! PS - CGGorman, the clips are there on the brake pads; thanks for the suggestion.
Old 11-10-2005, 02:51 PM
CGGorman's Avatar
Well, that's a new one! Must have come loose in a big hit?
Old 11-10-2005, 10:03 PM
There's no signs of any type of suspension damage that might have caused these to break loose like that. Seems to me the spot welds were just weak. I have the original wheels and tires and also no indications there either. Strange I know, but at least I located it. Those stupid hats were just rattling around against the strut stems. Been driving the car all day ... completely revived!! I'm a happy camper !
Old 11-16-2005, 04:19 AM
TWygant TWygant is offline
If you're getting noises going over bumps, check out the sway bar bushings, too. They're cheap to buy (about $5 each), but they can be a son of a gun to replace - especially the passenger side. Mine failed about 75k miles, but after replacing them, the noise went away completely and the drive was like new again.
