Old 11-08-2005, 01:46 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
tps questiom
Will a broken tps make my car run like poo? My tps is broken and the car has a very irratic idle and really sucks on the road.
Old 11-08-2005, 02:48 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: tps questiom
Throttle Position Sensor... I'm guessing it would cause your car to act like that... Should be a thread on how to fix that.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 11-08-2005, 02:52 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: tps questiom
Take a flathead screwdriver, put it on the small rivet-looking screws and smack it with a hammer to put grooves in the screws. Then back the screws out to get the tps off the throttle body. You'll most likely have to do the same thing to get a replacement one from a junkyard. Save those screws you made the notches in and just screw the tps back into place.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 11-08-2005, 02:59 PM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
Re: tps questiom
you'll need a multimeter to adjust the tps for the correct settings. correct me if i'm wrong.
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 11-08-2005, 03:11 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: tps questiom
first off, if you decide to take off the tps, get bolts dont put back on the screws you took off. second measure the volts of the middle red/blu wire. it should be .5 at closed throttle and 4.5 at open throttle. now if you want you can do it at the ecu, i think its like pin C8 but idk somebody confirm that, i havent looked at the wiring diagram in months
Team Lonely Drivers
Old 11-08-2005, 05:02 PM
Smoghog Smoghog is offline
Re: Re: tps questiom
Just a slight correction WOT voltage should be around 3.9v for some reason honda's TPS's don't go the full 4.5v.
Also when testing move the throttle slowly and watch the voltage. Make sure there are not any throttle positions that give voltage drop's (flat spots) The voltage should increase/decrease smoothly.
SH
Old 11-08-2005, 05:16 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: tps questiom
.49 when closed. 4.5 when open. numbers are approximate. i always get readings of 4.5 when i do WOT tps voltage measurements. 3.9 looks too low..................... low battery? short in the wiring? inaccurate multimeter?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-08-2005, 05:35 PM
I am first to admit I was wrong and I am. I got my numbers wrong 3.9v is for the map. TPS is 4.5v Sorry
SH
