Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 11-08-2005, 01:17 PM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
Turbo???
where can i get a turbo kit for my SPI focus 01 se (4dr) want to make it turbo and get some head work knive edged crank shit like that, juss caz no one does it to a SPI and noone would expect it.. any info?
Old 11-08-2005, 06:16 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
Re: Turbo???
umm lots of people turbo SPI's what do you think all the turbo's escort sedans from 91-2000 were?
you have to build your own turbo to my knowledge no one actually SELLS a SPI turbo kit. they can make over 300whp
Old 11-09-2005, 05:51 PM
mr_tw's Avatar
mr_tw mr_tw is offline
Re: Turbo???
dpending on what you intend to do like, what your goals are forotal hp a supercharger may be better for your needs (I'm a turbo guy myself, but sometimes a supercharger is just better) with a good roots style blower, bot only is it easier to package under the hood, but it dosent screw with the emssions as much as a turbo and you get (with a properly sized blower) lots of low end punch and lots of top end as well, on most 4cyl cars a suercharger is better because they lack the hit off the line, and that a supercharger can provide, and hey are usually cheaper and slightly easier to find, not tosay that they are easy, but not qute as hard, but whatever you choose good luck and have fun smookin Civics with the SPI lol
What Is With The Hatred Between Imports and Domestics? In The End, We All Love Cars.
Old 11-11-2005, 10:34 PM
Banned
Re: Re: Turbo???
thanks man, if i put a supercharger on my foci... is there any other mods im goin to have to do to the engine?
Old 11-12-2005, 12:07 AM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
Re: Turbo???
You don't really have to do it, but rebuilding it with strengthened internals will help it's reliability, and would probably give you a tad bit more power as well.
-Chuck
Old 11-12-2005, 09:00 AM
Banned
Re: Turbo???
well i was thinking about takin it out and takin it down the street to this place called kammer & kammer. its an engine shop. friends had alot of work done there, good place. decent priced. but ima have it bored and ported..and order my supercharger/turbo kit.. would the boring and porting. be a good thing too?
Old 11-12-2005, 02:39 PM
Banned
Re: Turbo???
i have never seen a SC'd SPI, turbo is much better for an SPI motor
Old 11-12-2005, 08:46 PM
Banned
Re: Turbo???
whys that?
Old 11-12-2005, 08:48 PM
Banned
Re: Turbo???
they are known to respond well and there is already a lot of literature on how to build a turbo'd SPI.
Old 11-13-2005, 01:14 AM
Banned
Re: Turbo???
and where would i find a turbo kit for an SPI, and where would i find the literature?
Old 11-13-2005, 11:08 AM
Banned
Re: Turbo???
you have to build one, i dont know of any place that makes SPI kits. a lot of escort sites have been building SPI turbos for years, you can also try Focaljet.com and focusfanatics.com
Old 11-19-2005, 03:32 PM
mr_tw's Avatar
Re: Turbo???
Building your engine is entirely up to you it really depends on how much power you want to want to have, and the porting (you should also polish at the same time) is a good idea as it helps air flow at high rpm and with work well with forced induction on low boost you could probably get away with it, but you have to mke sure that your injectors are up to the task of pumpin in enough gas (not sure if they are or not, but i'm sure somone here with know what you need to beef up for what boost you wanna use) as for the Turbo vs. Supercharger, it really depends on what you want, if you are going for lots of power and a higher level of boost then most definately go Turbo, but if you just make a few rips to the track and drag strip, and mostly use your car as a daily driver, you would most likely get along best with a good Roots tpe Supercharger, the main reason for this is that they have no spool up time, the power is right there right now, you can get a turbo that spools up really fast, but the quicker that they spool the more pricey they get, (since the development costs are that much higer to provide the turbo with quick spool characteristics and decent flow) the Supercharger on the other hand is always spooled and ready to go. The instant torque will make you much happier on a daily basisas al you gotta do is stomp the gas and go, a roots type isn't the only choice ether but it's what i would chooce on a small 4 banger simply becuse i spend more time driving to work and just running errands and such than i do running at the track and at full throttle, so it just make a far nicer car around town, but good luck man whatever you choose you'll have fun
