Old 11-08-2005, 12:14 PM
harryliuusa harryliuusa is offline
is it engine or transmission problem?
1999 T&C with 104k
The van started acting slow from 90k. The sympton is as follows: van sometimes pick up speed pretty fast at traffic light but it may hesitate and vibrate at the next traffic light.
I am so confused what's causing this. It coasts smoothly same as most of members's experiences.
This hesitaation may happen at the first gear to 2nd or 2nd to third (more often).
Is my engine not clean or the tranny?
Old 11-08-2005, 01:34 PM
WPAGEJR WPAGEJR is offline
Have You Had The Transmission Flushed And Had The Filter Changed?
Old 11-08-2005, 03:14 PM
Vats Vats is offline
when did you last change the leads and spark plugs?
Old 11-08-2005, 10:20 PM
Re: is it engine or transmission problem?
9k miles ago/6 months ago
Old 11-08-2005, 10:23 PM
Will do trans flush in one to two weeks, trans filter was changed 60k (now it is 104k), oil filter just changed 700 miles past
Old 11-08-2005, 10:39 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
check under your hood while the engine is running and listen for a whistling noise, either loud or soft. You could also, possibly, have a vacuum leak in your intake manifold.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 11-09-2005, 05:55 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Did you ever consider the possibility that the cat may be going bad. Failure to exhaust gasses from the engine can cause loss of power and the sluggish symptoms you describe.
Old 11-09-2005, 02:39 PM
Re: Re: is it engine or transmission problem?
is it something that computer diagnosis will show?
dealer could not locate any error code at this moment.
Old 11-09-2005, 06:44 PM
B33p3r B33p3r is offline
Also check your air intake duct from your air filter. If it's opened up anywhere, you can suck air in, bypassing your sensors. This in turn could cause your computers to adjust things wrongly. Long shot but a cheap check.
Old 11-10-2005, 05:41 AM
Pontiac Guy
Computer analysis in its true sense will not detect a bad cat unless the plugs are fouled to the point where you are getting misfires. One symptom is a loss of power and it will gradually get worse. With the mileage you indicate this is a possibility. Also what B33p3r indicated is also true so you may want to try his suggestion first.
Old 11-22-2005, 07:48 PM
cyclonicblade cyclonicblade is offline
a 97 caravan I worked on did throw a code for the cat somthing like a high backpressure code but it told us to that the cat was bad so u might want to get the codes read somewhere
Old 11-23-2005, 11:19 AM
Transmission flushed and engine cleaned with Auto-RX. The condition is 80% improved.
