Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-08-2005, 06:36 AM
surferfletch surferfletch is offline
Rodeo still leaking coolant
Quick summary as I have to go to work. After changing the water pump, water pipe o-rings, timing belt, thermostat, etc., I am still getting a leak of coolant which seems to be coming from the back of the engine. Seems to leak only after heating up. I'm overheating, too, because I hear the coolant boiling. Gonna park it. I don't have the temp guage so I don't know exactly how hot it's getting. I'm going to swap the rad. What else am I missing?
Also is the rad in the 4 cyl the same as the 6?
I want to order from radiatorbarn.com, but the only option is for the 4 cyl. Any other place to get it? Thanks for all help!!
Old 11-08-2005, 02:30 PM
Re: Rodeo still leaking coolant
Got one for $207+tax at NAPA. I'm hoping that low flow through it started causing the engine to run hot and push coolant out through a weakly clamped hose. Wishful thinking? I'll let you know!
Old 11-08-2005, 04:01 PM
The temp difference in the hoses is more pronounced now. The new radiator took the coolant and distilled water in much quicker. Seems flow was reduced in the original one. Going out for a ride and top up the ATF...
Old 11-08-2005, 04:34 PM
All back together. No runs, no drips. I imagine the o-ring failure at the ends of the external coolant pipes may have come a little sooner with the engine running hotter the last few months. Knock on wood, she's good to go for a couple of months now...
Old 11-09-2005, 09:51 PM
Maybe not. I added about a quarter of a quart to the reservoir tonight. My daughter drove it all day today. I'll have to get a closer look tomorrow. Any suggestions?
Old 11-09-2005, 10:16 PM
rodeo02 rodeo02 is offline
Could it be where that coolant Y-pipe connects to the rear of each cylinder head? I'm not sure what type of seal is used between the pipes and the heads, but it might be something to check (unfortunately !@#$).
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-09-2005, 11:26 PM
amigo-2k amigo-2k is offline
Isuzu Guy
I would give it a day or two. after you drain a system it will burp some of the air out and will suck over a little juice.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 11-10-2005, 07:21 AM
Thanks for both of the suggestions.
I can see that pipe at the back of the heads and the seal there is bone dry on both sides. There are 2 paper type gaskets there. I'll keep checking, though.
I'm keeping my fingers crossed that Ryan's thought plays out! I'm not seeing any coolant on the ground.
Old 11-10-2005, 05:07 PM
Feltch- No visible leaks is a good thing. Like Ryan says, it's near impossible to get the system totally purged of air & takes awhile to fill the air pockets. I bet that's all it is!
G/luck
Joel
Old 11-10-2005, 05:44 PM
Thanks! I added less than half an inch to the reservoir today, and nothing but A/C condensate on the ground. I'll sleep better tonight knowing the wife was wrong ("Just trade the damn thing in!").
Old 11-10-2005, 08:32 PM
Re: Re: Rodeo still leaking coolant
Originally Posted by surferfletch
...("Just trade the damn thing in!").
Uhoh... You already got the blessing from the 'board of directors'?. Let the fun begin .
G/luck
Joel
