Old 11-08-2005, 02:53 AM
werdy666 werdy666 is offline
Angry Paint Stripping Problem
Hi,
I kinda stuff up when I was spraying my F40 model. I used both enamel and lacquer and now the paint has cracks.
I have been unsuccessfully trying to soak the body of the car in brake fluid. I know it works because I had another model i wanted to respray and after 1 night the paint nearly slid off. but the ferrari will not budge after 5 days in the brake fluid.
Any suggestions on how to remove the paint?
Thanks
werdy666
Old 11-08-2005, 02:58 AM
mickbench's Avatar
mickbench mickbench is offline
Odd. DOT 3 /4 always works for me. Have you tried 99% Isopropyl Alcohol?
Old 11-08-2005, 03:34 AM
Yeah Not sure what dot it is, but its castrol brake fluid.
Will try to obtain some Isopropyl Alcohol. hopefully its over the counter stuff here in australia.
what about methylated spirits? i know thats like 99% alcohol, with a touch of ethanol in it so u can't drink it. would that work too?
thanks
Old 11-08-2005, 03:37 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Re: Paint Stripping Problem
I'm sure dot3 work well on both kind almost after 24h
gio
Old 11-08-2005, 06:03 AM
BWheel BWheel is offline
Try using oven-cleaner. This can strip paint very quickly, found better on enamel/ acrylic than on lacquers though.
Completed:
Tamiya Subaru WRC Monte-Carlo
Revell Eddie Hill Top-Fuel Dragster
Revell T900 'Australia'
Tamiya Enzo Ferrari
Tamiya Honda NSR
Current Project:
Revell Fire Truck
Old 11-08-2005, 06:53 AM
klutz_100's Avatar
TAke a look at this thread from a couple of weeks ago. There's a lot in there you might find helpful.
http://www.automotiveforums.com/vbul...d.php?t=471792
Best of luck!
Old 11-08-2005, 11:02 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
Re: Re: Paint Stripping Problem
And if ya don't find what you need there . . . I've used Lestoil and Pine-sol to strip stubborn paint off of delicate resin and diecast before with the same "slips right off" results . . . Worth a try. .
Best of luck!
Chuck
Old 11-08-2005, 11:10 AM
Monster_20 Monster_20 is offline
I also have a model that need to have paint stripped. It is a heavily modified 996 (from a 996 GT3 to 996 Turbo) with lots of putty work. Is oven-cleaner safe for putty?
Thanks in advance.
Old 11-08-2005, 06:23 PM
boostspike's Avatar
boostspike boostspike is offline
from my personal experience, the oven cleaner chemical ate away the putty... (tamiya basic putty). not sure about other putty type.
Old 11-08-2005, 06:38 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Thanks in advance.
What's it painted with?
PHOTOBUCKET SUCKS
Old 11-09-2005, 03:43 AM
Lightbulb
Thanks for all the great advice guys.
I went to my chemist and purchased like 25ml of 99.5% isopropyl alcohol. $2.50! Sometimes I wish i was a yankie instead of an aussie!
Sounds like i could get isopropyl alcohol that is about 60% - 70% for alot cheaper. Obviously it would take longer but will it still work effectively?
One last question on the Alcohol. Would Methylated spirits be ok? That stuff here is like 99.5% Alcohol and .5% Ethonal. what does the ethonal do to plastics?
Thanks again Guys....
Werdy666
Old 11-09-2005, 08:23 AM
Re: Re: Re: Paint Stripping Problem
It is painted with Tamiya Can, and putty is the Epoxy (2 mixed in 1) type.
Old 11-09-2005, 08:34 AM
MPWR's Avatar
Re: Re: Re: Re: Paint Stripping Problem
For stripping Tamiya TS, use isopropyl alcohol. Soak in covered container, scrub loose paint with toothbrush. Shouldn't be a problem for your putty work.
Methylated spirits should do the same as isopropyl. I use isopropyl because its cheap here- if it wasn't, I'd use methylated instead.
PHOTOBUCKET SUCKS
