Old 11-07-2005, 11:00 PM
99`_grand_am 99`_grand_am is offline
Send a message via AIM to 99`_grand_am
what does ets stand for?
on my 99 se, theirs that ets button next to the hazards light, when pushed nothing happens, no light comes on or nothing, so what's it for?
Old 11-08-2005, 08:16 AM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
I believe thats the traction control switch. Turning it on or off you won't notice a difference unless its either icy, snowy or you are beating the hell out of your car.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 11-08-2005, 08:26 AM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: what does ets stand for?
It should illuminate "Trac Off" on your dash, up near the upper right-hand side. If it doesn't, then either your ETS isn't working, or your idiot light is burnt out. And like skibum said, the traction control is used to control your grip. If it detects differing speeds from your vehicle speed sensors in each hub, it will lean your a/f ratio and cut timing until your rpms drop to the point where the speeds are the same (i.e, you "hook up") - Turning off ETS though is actually one of the first things I do whenever I get into my car. If you're just driving aggressively on dry pavement, it can make a big difference in big launches, even when there's not much slippage. In the snow and rain too, I actually always turn mine off. I'd much rather be able to feather the throttle the way I want until it grabs rather then have the PCM try to do it for me.
Old 11-08-2005, 08:39 AM
SLP makes a different switch for the f-bodies that turns off the ets when you start the car, don't know if anyone makes one for the grand am's...
Yup, I own the suv.
Old 11-09-2005, 09:33 AM
01Z's Avatar
01Z 01Z is offline
I know it's called ASR on my camaros and the SLP start up state reversal unit is $70 from Summit Racing.
BTW, my son's 96 Grand AM has the ETS (Enhanced Traction System) warn light is illuminated. Once the car is started it can be toggled off but comes back on shortly because the ABS has become non-functional. I didn't stop to think that this was affecting engine performance. With 140k the car is hardly worth the expense to fix these things but I sure would like to over ride them....
Regards
01 Z28 M6 - 95 Z28 A4
Old 11-09-2005, 10:43 AM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
If i recall it should be the last light on the speedometer side just past service vehicle soon light. ETS also could stand for Electrically Troubled System ( or at least thats mine)
