Old 11-07-2005, 10:58 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Porting tools
I just had a couple questions about porting. Not necesarily on the porting itself, but the tools. Will a dremmel work or do you need a die grinder? Will an electric die grinder work, or will I have to get a pneumatic one? I do have an air compressor, so that doesnt matter. Mike is soon getting an exhaust manifold and we plan on porting it along with the o2 sensor housing. Thanks guys, I appreciate your input.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-07-2005, 11:20 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Porting tools
a Dremel might work but you'd sit there for days
pneumatic for the win!
now - 2000 civic
soon - 2002 is300
Old 11-07-2005, 11:30 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Porting tools
use a die grinder to get the majority of it and then the dremel to finish that baby off, you'll have her looking like a $1000 port job in no time with just a little effort. just watch and make sure you don't over-port and screw up the head.
95 Talon TSI AWD
97 Eclipse GST
Old 11-07-2005, 11:36 PM
ted_ex's Avatar
ted_ex ted_ex is offline
Re: Porting tools
The ait powered grinders are the best overall. However, if you don't have a fairly large compressor and tank, you will have to stop a lot to let the compressor catch back up. I have a 6hp 30gallon compressor and it keeps up. I actually just finished porting my 2g head to accept a 1g intake (huge difference). I have pictures I'll try to post in the next day or two.
I'm>everything
Old 11-07-2005, 11:58 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
http://all.dejonpowerhouse.com/edit/A-04.htm
All the way at the bottom.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 11-08-2005, 01:55 AM
Re: Porting tools
yeah i had a problem when i ported my head that the bit kept clogging up. just make sure you keep it cool and always wet with some form of cutting oil or fluid, otherwise it'll start to jump around and fuck up the porting job.
95 Talon TSI AWD
97 Eclipse GST
Old 11-08-2005, 07:18 AM
Thor06's Avatar
Jizzed In My Pants
Re: Porting tools
Awesome, thanks guys. We'll get his new manifold in about 2 weeks and we'll port the 02 housing and the exhaust manifold first, and then I will buy a head to work on this winter. My compressor is a 35 gal 6 hp, so it should do fine. Would I just use that one bit (from clipsekid's post) or should I get a few of different sizes? So what about the "polish" part of porting and polishing the head? Do you just use a "polishing" bit on the die grinder?
Old 11-08-2005, 02:15 PM
Re: Porting tools
the die grinder will be used to take down the majority of it and then use a dremel with the sandpaper tubes. that's how you smoothen it out. start with like 180 grit and then 220 and then keep going up from there until its where you want it. just be sure that when you port the head...the intake ports don't get polished as much as the exhaust manifold, it helps for better atomization of the air and fuel. but the exhaust ports should shine like a mirror.
95 Talon TSI AWD
97 Eclipse GST
Old 11-08-2005, 04:49 PM
Thor06's Avatar
Jizzed In My Pants
Re: Porting tools
Thanks a bunch gthompson97, I really appreciate the advice. I just cashed my last two pay checks and a check from my birthday (not too much, but pretty good considering I can only work weekends due to extracurricular activities) and I think I will take a trip to homedepot this week for the tools, and next check I will get a head and get to work. I kinda wanted a winter project, now that Mike is porting his exhaust manifold, I get a reason to buy a head to rebuild Thanks again guys.
Old 11-08-2005, 05:10 PM
ted_ex's Avatar
Re: Porting tools
http://www.sa-motorsports.com/diyport.shtmCheck out this site. Tons of good information and they sell all the tools you need. You can order the porting kits they make from summit.
I'm>everything
Old 11-08-2005, 06:35 PM
Re: Re: Porting tools
i was lookin for that damn site lastnight, i have is saved in favorites on my other computer, that's a good site to follow. but home-depot bits would do perfectly fine and a dremel kit.
95 Talon TSI AWD
97 Eclipse GST
Old 11-09-2005, 12:35 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Porting tools
They don't sell carbide burs at home-depot do they? I know they sell little ones for dremmels but thats it. If your porting steel you need a carbide bur.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 11-09-2005, 04:29 AM
Re: Porting tools
oh i'm not sure, i don't have a home-depot in my home town. i got it at an automotiveparts/engine building shop.
and the head isn't steel, it's aluminum.
95 Talon TSI AWD
97 Eclipse GST
Old 11-09-2005, 04:11 PM
ez1286's Avatar
Re: Porting tools
I know, i meant for the exhaust manifold.
Old 11-09-2005, 06:24 PM
Thor06's Avatar
Jizzed In My Pants
Re: Porting tools
The 4g63 is and iron block right?
