Old 11-07-2005, 10:41 PM
altered.state altered.state is offline
Send a message via MSN to altered.state
Coolant Leak
New to this i have a 2002 grand am se , seems like once every week i have to fill the car up with coolant , by looking on my driveway i can only see lil spots of where it has leaked out , but cant find the leak anwhere under the car , the spots seem to be almost near the middle of car and to driver side ... any help with this please... the heat works fine but temp is always at 90-96 c for us canadians i dont know if thats to high or not ?
Old 11-07-2005, 10:46 PM
99`_grand_am 99`_grand_am is offline
Send a message via AIM to 99`_grand_am
diy?
i put purple diy in my ac coolant, and i found the hole, maby it could work with the coolant porblem you havem trying to find the hole and all... but the diy, mught not be to good for that.. so i dont know,
Old 11-08-2005, 05:35 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Coolant Leak
The easiest way to locate a leak is to place cardboard under the car and let it sit. If there is a leak it will show up on the cardboard and give you an idea where it is coming from based on the location on the cardboard. In your case I would check the oil to see if it is milky (looks like chocolate milk) if it does you have a leak in the intake manifold gasket and need to replace it. If not then look for an external leak like a bad hose, leaky thermostat housing or sensor. Once you try the cardboard trick you will probably be able to identify where it is coming from.
Old 11-08-2005, 07:44 AM
crys36 crys36 is offline
Send a message via AIM to crys36
Re: Coolant Leak
Have the mechanic check your intake manifold gasket and also look for cracks in it. These cars on the intake were made pretty cheaply. After I had my Intake manifold changed with 1 from the junkie (100$ compared with400$ from the dealer). 2 Cracks right where sensor fits. Now I have a new planter for my front yard.
