Old 11-07-2005, 10:31 PM
newbicivic89 newbicivic89 is offline
Need Help Bad
I warped my head on my 89 4dr civic. I got a new and then put it on. I got in and crunk the car up. I was happy cause took a little long to get the new head. Well i forgot that the radiator hoes busted so i turned the car off put the new radiator hose on and went to crank it back up and it didnt even turn over. So i bought a new starter and still dont turn over anyone got any suggestions?? Any would be nice.
Old 11-08-2005, 07:38 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Need Help Bad
Check your grounds. Maybe one came loose... like the one to the thermostat housing... since you did replace the hose and had to put all that stuff back together... GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 11-08-2005, 07:42 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: Re: Need Help Bad
i def agree with that! i had the same prob b4 and forgot to hook that small ground up and the starter didnt even engage.. you'll be straight!
Old 11-08-2005, 07:50 AM
doug294 doug294 is offline
Send a message via AIM to doug294
Re: Need Help Bad
Yeah check your grounds for sure. On a side note, 91 Civic why don't you make a progress post for you mod list and some pictures. Your mod list is longer than all three post lol
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 11-08-2005, 12:26 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Old 11-08-2005, 12:40 PM
894drcivic 894drcivic is offline
Re: Re: Re: Need Help Bad
OK thx ill check and get back with you.
Old 11-08-2005, 05:55 PM
Re: Re: Re: Re: Need Help Bad
Nope didnt work stii not craking.
Old 11-08-2005, 06:22 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Need Help Bad
so you warped your b18c head ? and you got another b18c head ?
hows the timing ?
Team Lonely Drivers
Old 11-08-2005, 06:51 PM
Hybrid1990crx's Avatar
Re: Need Help Bad
uh, its still going to crank even if the timing is off. The start gets voltage directly from the battery, and then has its own ground. so its either in the wiring, or ignition. maybe your battery died.
Old 11-08-2005, 10:19 PM
not battery cause i tried to jump it off.
Old 11-08-2005, 10:27 PM
i konw hte car will still crank with the timing off. im just curious as to what the timing is because he makes it sound like he did this himself
Team Lonely Drivers
Old 11-09-2005, 06:03 AM
Re: Need Help Bad
can you hear your fuel pump turning on? have you check for fuel pressure?
Old 11-09-2005, 06:31 AM
YEa right befor i turn the key all the way over i can hear a little humming noise.
Old 11-09-2005, 11:18 AM
Re: Need Help Bad
do your dash lights come on when you turn it over?
Old 11-09-2005, 12:07 PM
My battery is not dead cause i can still listen to my radio and turn my headlights on.
