Old 11-07-2005, 10:36 PM
Cowboy20th Cowboy20th is offline
Got a hard one for you guys.
ok, I know this is a chevy forum, but the GMC forum aint too active. I own a 99 GMC Sierra EXCab, 5.3L. I have recently gotton my brakes worked on, rear drums replaced, new rotors, new pads in front. I have noticed a knocking sound coming from my front left tire. The tire is in good condition, just rotated and balanced. Could I have a brake problem? Or maybe just a wheel bearing hub going out. Thanks for any help.
Old 11-07-2005, 10:58 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Got a hard one for you guys.
I woild say wheel bearing, but does it only do it when you stop or what?
Old 11-07-2005, 11:07 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
you don't think it could be the steering shaft, do ya? FYI, IMO 99-up GMC guys are welcome over here
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 11-08-2005, 08:30 AM
poetater poetater is offline
Loose wheel bearing.
Old 11-08-2005, 07:22 PM
no, it stops doing it when i apply the brakes quickly, and it only does it really at higher speeds like 45mph-80mph, and not when i accelerate. I hope it is the wheel bearing, i know those arent too expensive, thanks for all the input.
Old 11-08-2005, 09:19 PM
rustcal rustcal is offline
Send a message via AIM to rustcal Send a message via Yahoo to rustcal
my buddy had the same problem with his 99 gmc, if i remember rightly it had something to do with the steering linkage. sorry i can't be more accurate. it was like 4 yrs ago when he had the problem.
Old 11-08-2005, 10:36 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
uhhh , not expensive for the wheel bearings ? Try approx $300 per side, the bearings are not serviceable and the entire hub assembly needs replacing unforutnately.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 11-08-2005, 11:08 PM
ricebike ricebike is offline
return it to the shop who did the work immediately
Old 11-10-2005, 08:20 AM
dannymoz71 dannymoz71 is offline
Send a message via Yahoo to dannymoz71
I had a 98 that was making a noise like that. Ended up that the upper A arm had a loose mounting bolt, so that when brakes were applied the A arm would move and make a noise.
Old 11-10-2005, 08:59 AM
Re: Re: Got a hard one for you guys.
yup, hence my recommendation to take it back to the shop; they reassembled something incorrectly... make them recheck their work!
