Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-07-2005, 08:25 PM
gobber gobber is offline
Angry no signal lights
The signal lights on my 92 mustang quit working.I check the fuse and it is good,all the bulbs are good and the 4 ways work.Replaced what I believe to be the 4-way flasher and it still doesn't work.I read that there is a flasher for the signal lights, does anybody know where it might be located and what it looks like.
Old 11-30-2005, 09:20 PM
kmathew kmathew is offline
I'm not familiar with your model, but hteir is onl two places to look. One is under the hoodon the drivers side, and the other is on the drivers side in a fuse panel down by the kick panel. The flasher unit is usually about 1 to 1 1/4 inches in diameter. It's usually under the dash.
Good Luck
Old 11-30-2005, 09:52 PM
Interstate526's Avatar
Interstate526 Interstate526 is offline
Re: no signal lights
it is probably under the dash. its a plastic or metal cylinder about an inch tall. it should just plug right in.
"All good things are wild and free"
-Henry David Thoreau
