Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-07-2005, 08:23 PM
tymoney1980 tymoney1980 is offline
Question vafc
instead of buying the vtec ecu can u use only the vafc to engage the actuall vtec
Old 11-07-2005, 11:37 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Re: vafc
What? If you're asking if you can use a VAFC to magicallly engage vtec in an engine that doesn't have it, then no. And just putting a vtec ecu into an engine that doesn't have vtec won't work either. If I'm off here let me know, but that's what I'm seeing your question as.
Old 11-08-2005, 12:46 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: vafc
idk about the VAFC, but an AVC-R controller might be more what you're looking for.....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-08-2005, 09:30 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: vafc
I think he did the LS Vtec and is wondering if you can activate VTEC without a the proper ecu. Mechanically, the answer is yes you can have an RPM dependent switch that manually operates VTEC (you can use a shift light circuit as the actuator) although you will need also a switch to deactivate it once it is on.
The proper ECU, however, provides you with the proper fuel and ignition maps, so unless you were using Uberdata, Hondata, or another chipping mechanism of some sort where stock fuel maps are inconsequential you may want to consider the hassle-free use of the proper ecu.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
