Old 05-27-2002, 03:56 PM
grncivicdhr's Avatar
grncivicdhr grncivicdhr is offline
AF Premium User
Send a message via AIM to grncivicdhr
Question engine designation question
i have a question...my 97 civic ex has a d16y8 SOHC vtec engine...at least that what i understand. Heres the question tho, what is a ZC engine? is this another SOHC vtec engine or is it a jdm version of my d16y8?
Old 05-27-2002, 04:14 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
the ZC engines can be found in 90-93 acura integra LS/RS. it's a DOHC engine WITHOUT VTEC. the ZC engine puts out 137hp and 108ft. lbs. or torque. unlike the D16Y8, the ZC reline is at 7200RPM.
I love them sub wufers
Old 05-27-2002, 04:24 PM
AF Premium User
thanks
thanks, i guess the zc is a jdm version of the b18a?
Old 05-27-2002, 04:32 PM
GSteg's Avatar
Re: thanks
ZC is actually a USDM engine. it's from the 90-93 USDM integra. it's not a JDM version of the B18. the ZC is a 1.6 liter engine
Old 05-29-2002, 12:48 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
The ZC is NOT a USDM engine.
Its a HONDA ENGINE! damn enthnocentric yanks
It was sold all over the world and started life in the 3g Civic Si, and was last used in the 5g Civic GTi. It was also used in the 1st and 2nd generation Integras.
As a result there are a variety of differnt versions, and Hp ranges from 120 to 135.
Its a good solid engine that makes a good honest amount of power and is very easily tuned.
They are basicly a standard 1600cc D series block with a Twin Cam head on the top. Altough swaping the head onto another D series engine is not possible as some of the oil passages and water gallerys where changed to accomdate the differnt head.
The head is a slightly redesigned version of the Twin Cam head found in the Si versions of the old 80s prelude, the B20a. It was this engine that the first VTEC B16a and later B18a and B18c were derived from, hence the very strong technical and visaul similarity between the ZC engine and the B series engines.
The ZC is now quite cheap especialy when compared to its more popular stable mate the B16a, and a $ per HP basis is a much better buy. Hence its a very popular swap into many 4g Civics and CRX's, as it offers quite a performance boost over the old D16/15/13 engine, but requires very little work as it will fit the cars existing engine mounts and gearbox, and requires very little extra wiring.
For the same reason if you have the time to carry out an EFI conversion its all an excellent engine for the older 3g Civic and CRX, and if you live in a state or country where OBD and emissions/compliancing are not a problem it can be easily fitted to a 5g or later Civic.
Old 06-02-2002, 10:13 AM
HonDork HonDork is offline
Send a message via AIM to HonDork
Not to mention the info I've read on it says it's a 1.7 liter engine
meep meep!
Old 06-02-2002, 08:42 PM
Moppie's Avatar
Master Connector
WHICH IS ALSO TOTALY WRONG!
Old 06-02-2002, 09:38 PM
VTEC_boi's Avatar
VTEC_boi VTEC_boi is offline
Send a message via AIM to VTEC_boi
Good lord guys, Moppie's your daddy so listen to him!
ZCs are 1.6L DOHC non-VTEC engines and make 127, not 137hp.
The 90-93 non-GSR Teg has a B18A which is a 1.8L DOHC non-VTEC motor. The 1.7L is the B17A which is a USDM engine and is DOHC VTEC and makes 160hp.
GSTeg, do more research because giving false information can really screw a guy up.
Hey Moppie! i'm a yank and i'm not screwy
"Son, your eyes look a little red there. You've been hittin the Vtec haven't you? Alright, stand on one foot, touch your nose and say 'Third Rocker Arm'".
Original PH Member (Reppin' for original PH'ers!)
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
Old 06-02-2002, 09:58 PM
GSteg's Avatar
i was looking that up at hybrid honda.com, but they only mentioned the ZC on 90-93 integra so i went from there...god..who knows how many damn engine they made:finger:
Old 06-02-2002, 10:20 PM
Moppie's Avatar
Master Connector
I dont think Hybrid Honda has been updated since the day it was made.
Its not really the most accurate site.
And they are not even remotly clued up on JDM Honda's.
And VTEC_boi Your still a screwy yank.
The ZC came in a variety of differnt levels of tune, including a Twin Carb version.
So hp ranges from 120-135hp.
Generaly the older the engine the less hp.
Old 06-02-2002, 10:24 PM
GSteg's Avatar
so do i get the blame for being wrong?
Old 06-02-2002, 11:23 PM
I stand corrected so which car in the US got the 1.7...GS, RS, LS?
meep meep!
Old 06-02-2002, 11:26 PM
Actually nevermind...brainfart...LS is non vtec so is RS. DUR
meep meep!
Old 06-03-2002, 01:10 AM
Moppie's Avatar
Master Connector
yes.
It just shows that you shouldn't always believe what you read on the internet.
especialy if its written by Americans and is about something only a VERY few of them have ever actualy seen, or had any real experiance with.
Old 06-03-2002, 08:12 AM
GSteg's Avatar
yes.
so how do i know if it right or wrong?
