Old 11-07-2005, 07:19 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Talking Cleaned TB!
My god, I love it!
I cleaned my TB for the first time ever. I took off the sensors and took off the TB off the manifold. Bought some TB cleaner (STP). When I took it off, the whole backside of the flapper was thick and chunky with black gunk. The inside of flapper to the manifold was filthy too. Insane filth. I let it soak in the cleaner, and cleaned the sensors. Put it all back, adjusted the throttle cable tension, and god damn!
I can't believe the difference! Repsonse is quicker. Idle is smoother. And when accerlating from a complete stop (normally), when droppng the clutch, there is no jerk. You can't feel when the clutch is fully dropped. IDK why that made a difference, but it's awesome.
I suggest for everyone that hasn't cleaned the TB, take it all apart and do it. I also cleaned a little inside the manifold, and took pipe cleaners to the PCV and EGR pipes. I suggest that too! Great difference. Next, getting the TB ported.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-07-2005, 09:50 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Cleaned TB!
Nice work. This is one of those maitnenance things everyone over 60-100k miles should be doing, but no one does it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-07-2005, 09:54 PM
Killa's Avatar
Killa Killa is offline
I think I got same engine as your 97 rs, is that really hard to do ?
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 11-07-2005, 10:32 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Cleaned TB!
hard to do? nope it's easy as pie. specially in the 420a. all you have to do is remove the 2 bolts, gas pedal wire thingy, and the harnesses. unlike the 4g63. we have 4 bolts,coolant lines, sensors. and for turbo we have to remove the cruise box in order to remove the TB.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 11-08-2005, 09:01 AM
david-b's Avatar
Dave is THAT guy
Re: Cleaned TB!
Yeah, if anything, it's WAY too easy. Don't loose the gasket that goes between the TBU and the IM.
75 Monte Carlo
Old 11-09-2005, 09:58 AM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
Re: Cleaned TB!
Anyone know a good link to an FAQ for how to clean the TB on my GSX? After reading this, I'm super pumped to pop the hood this weekend and clean it. I have a shop manual but it's in Florida.
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 11-09-2005, 05:45 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Re: Cleaned TB!
YEA!!!! I just opened up the throttle body today and ALOT, ALOT of black crap was everywhere!! EVEN on the intake tube!!
How does it accumulate there and what is it? Is it oil, or gas? Will it harm the car! THANKS!
I will definitly do this tomorrow!!
Old 11-10-2005, 02:18 PM
AF - Advisor
Re: Cleaned TB!
There is a lot of crud build up in the manifold from the EGR system, and oil from the valve cover gets all over the intake pipes, IC, and TB.
Kevin Jewer
Old 11-10-2005, 09:41 PM
Killa's Avatar
sup david-b , can you write up a step by step how to take those thing out, btw if any one know where I can find a faq about that please post the link thank you .
GM FOR LIFE !!
95 camaro lt1
Old 11-11-2005, 02:44 PM
Re: Cleaned TB!
Hey David B! How did you adjust/tighten the throttle cable tension?
Old 11-11-2005, 07:16 PM
david-b's Avatar
Dave is THAT guy
Re: Cleaned TB!
I will do a write up about it... since you all want one. Give me time
I did an article before on how to tighten the cable... just got to find it.
75 Monte Carlo
Old 11-11-2005, 07:22 PM
david-b's Avatar
Dave is THAT guy
Re: Cleaned TB!
Here we go
http://www.automotiveforums.com/vbul...light=throttle
There's a pic that shows where the tension bolts are. There is 2. The cable is connected to the plate those 2 bolts hold. You want to pull the cable back... not too tight. Then tighten the 2 bolts. For the best response, make sure when everything is attached, that the cable is pretty tight. No slack. This will give you great throttle response. It should be so tight, that when you put your finger on the cable by the tb, and barely press down, the TB plate should open. NO SLACK
75 Monte Carlo
Old 11-12-2005, 04:44 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Re: Re: Cleaned TB!
Yeah that cruise control box is annoying. Like the vapor line right over the tops of the uicp bolts. Couldn't you also just take the throttle cable off and turn the plate to clean the backside?
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 11-12-2005, 11:20 AM
Re: Cleaned TB!
I called my dad to have him scan and send me TB cleaning instructions and he told me to just take off the air filter and run a can of Gum Out (or Gunk Out) through the system. Is that safe for the MAF and turbo? Is it effective?
Old 11-13-2005, 07:46 AM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: Cleaned TB!
i tryed that tensioner to adjust the cable and it worked great i have much better throttle responce now,i know its sad that a thread about a simple tb cleaning and cable adjustment started all this craze about it but it shows you how untalented the rest of us are hahaha thanks for the tip man peace
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
