Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-07-2005, 04:08 PM
dicarlo7616 dicarlo7616 is offline
Question not idleing!! cant figure it out!
i had a problem with my alternator i just got a new one which works. but before i put the new one in i put a fresh battery in the car and took it around the block and it ran fine. now it will not idle smooth after the new alternator is in. It will run if i give it gas but its rough around 1,000-1800 rpms. the check engine light popped on once so i thought it could be an electrical problem so i checked fuses and connections. with no luck. now the check engine lights off i cant figure it out for the life of me. if anyone has any info for me please help me out.
Old 11-07-2005, 07:39 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: not idleing!! cant figure it out!
Hard to guess, but maybe try taking the car out to a dark area in the middle of the night and manually rev the engine by manipulating the throttle body. Look everywhere for an electrical short, particularly at your spark plug wires. Did you have this problem at all before changing the batt and alt?
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 11-07-2005, 10:11 PM
no this is a new problem. i go the car last week just started working out the problems now. but i did check the resistance of the wires. and one was a little low and also i checked the injectors and one has the smell of gas. so i'm going to pull it tomorrow morning and see whats up with that. do you think that would be a factor in not idleing. i'm just checking everything i know to be the problem at this point
Old 11-08-2005, 02:43 PM
Speednis Speednis is offline
Did you make sure the fresh battery had a full charge before you changed the alternator? How does the amperage (cca rating) on the new battery compare with that of the old battery? I noticed in my car when I put in a battery with lower cold cranking amps, the idle was not as good.
Old 11-08-2005, 05:11 PM
Talont28 Talont28 is offline
Send a message via AIM to Talont28 Send a message via MSN to Talont28 Send a message via Yahoo to Talont28
dont have a strut bar do you? i had the same problem batter terminal grounded out on it cuase idle problems......if its not that could be a throttle position sensor.....
Jesse
Its a Dsm thing...
<img src="http://www.dsmtuners.com/gallery/data/500/44010Pcdv0154-thumb.jpg">
