Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 11-07-2005, 03:58 PM
4x4trooper 4x4trooper is offline
TOD 4WD not working
i like to take my trooper off-road. the last two times i have went i got stuck in the sand. the reason for this is my TOD system is not working. when i turn it on into auto 4wd high, the TOD lights flash and the trooper never uses the front tires. when i put it into full time 4wd low, i feel the power in the rear but nothing in the front tires, and again the lights flash. Please help, i need to get back in action!
Old 11-07-2005, 05:35 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: TOD 4WD not working
How are your tires? Are they all the same size? Same Brand? Same mileage? Same Tire Pressure?
TOD likes all the tires to be exactly the same.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-07-2005, 11:35 AM
gear714 gear714 is offline
If your 4WD low (the manual lever) isn't engaging the front wheels either, you have the same problem as me. For some reason the front hubs aren't locking so TOD and 4WD doesn't work. Could be a speed sensor, an electronic control module, a vacuum valve or even something else. My mechanic only had a few minutes to look at it and couldn't find out which problem was causing it.
Old 12-07-2005, 02:27 PM
rodeo02 rodeo02 is offline
The front axle not engaging at all in TOD or 4x4 mode is most likely a shift on the fly actuator issue. IIRC- it's vacuum actuated on the troopers & will be mounted on the front axle tube.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
