Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-07-2005, 12:16 PM
Vheissu Vheissu is offline
Question No Spark and I need help desperately!!!!!!
I need help here, I have checked eveyrhting I can think of, plugs wires, fule filter/pump and I even changed the distributor, but it just won't start, it turns over but gets no spark to pop. I used to be able to get it going by hitting the steering wheel, almost everything is brand new on this car and I just don't get it. If any one has any ideas please [email protected] . This car is my only way arround.
Old 11-07-2005, 12:44 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: No Spark and I need help desperately!!!!!!
maybe the wires to the distributor are screwed up....use a test light to see if the distributor is getting power...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-07-2005, 05:36 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
no spark. hitting steering wheel will make it fire up sometimes? check the ignition switch. check for voltage and contiuty from the two ignition junction plugs of the solenoid and switch. actually, im not sure if integras come with two junction plugs. if your not sure what they are, go pick up a helms. there are specfic terminals of the ignition switch you must check.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-07-2005, 08:18 PM
V T E C H's Avatar
V T E C H V T E C H is offline
is your coil dead?
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
